Big Poppa's 514 dyno
+9
Straubtech
Albert Clark
o henry
13 posters
Page 2 of 2 Previous  1, 2
Big Poppa's 514 dyno   - Page 2 Empty Re: Big Poppa's 514 dyno
Post  Paul Kane December 18th 2017, 6:07 pm
IDT-572 wrote:
Paul Kane wrote:Very nice!  ...Also, what block?
D1 block 2 bolt main. Offset ground stock crank.
Big Poppa's 514 dyno   - Page 2 Icon_tup
Thanks.
Post  IDT-572 December 18th 2017, 6:09 pm
Paul, me computer won't let me reply to your emails. I have my IT guy checking on it .
Post  Lem Evans December 18th 2017, 8:12 pm
"Headers were dyno-tech big block Chevy's with a adapter to the ford head, 2 1/4 to 2 3/8, 32 inch long primaries with a 5 inch collector.
Makes you wonder if you can get too big a carb or too big a header on these engines. They always amaze me."
I hear you. I'm all in for your 1450 QFX but, I'm out on the bigger exhaust pipe dia.
Post  FalconEh December 18th 2017, 9:00 pm
Awesome build cheers
Post  IDT-572 December 18th 2017, 9:37 pm
FalconEh wrote:Awesome build cheers
Thanks.......... Wink
Post  jbozzelle December 18th 2017, 11:29 pm
Albert Clark wrote:OMG what just Amazes me is you did all this without consulting the God of All Gods on your cam and heads Shocked
in the Future Cartwright remember you can't do this with out consulting the Professionals. end of subject.
Oh and Up yours Cartwright
yours truly Albert
Old Albert always shows up at just the right time...
Good job on the build. Gives me confidence that my P51 headed 514 will make some good power. May need a cam change but I'll run it with Fabio's old junk roller and see what she does for 2018.
Post  IDT-572 December 19th 2017, 12:24 pm
yours truly Albert
It will run good............... Twisted Evil
Post  cool40 December 20th 2017, 1:01 am
Lem Evans wrote:
IDT-572 wrote:
cool40 wrote:How low did you go with timing on alky? I would have figured less would net more..... Suspect great numbers!
.      33 is as low as we went. Everybody says higher timing on alky, but this deal didn't like more.
Most of the time it's better to forget what you heard and just believe what you witness.
BTW....good job.
reason I asked Cool I have witnessed 26* on alky run faster at the 1/8 mile dyno.
Post  IDT-572 December 20th 2017, 10:33 am
BTW....good job.
I wished we would have tried a lower setting. I will have Kerry try dropping the timing at the track. When we lowered it on the dyno to 33 it carried the hp peak just a tick higher in the rpm range.
Post  bruno December 20th 2017, 10:39 am
Great build guys !!!
http://WWW.CKRME.COM
Post  IDT-572 December 20th 2017, 10:58 am
bruno wrote:Great build guys !!!
Thanks Bruno...........
Post  SandHillsHillbilly December 20th 2017, 11:04 am
Great job guys! Just goes to prove the capabilities of factory block and crank. Did you fill the block?
SandHillsHillbilly
SandHillsHillbilly
Post  IDT-572 December 20th 2017, 11:09 am
SandHillsHillbilly wrote:Great job guys! Just goes to prove the capabilities of factory block and crank. Did you fill the block?
No, it's not filled. Stock 2 bolt D1 block.
Thanks,
Post  glenevans December 20th 2017, 2:53 pm
Very nice
glenevans
Post  IDT-572 December 20th 2017, 2:55 pm
glenevans wrote:Very nice
Thank you Glen..............
