Big bore Windsor build
whitefield
FRPP 351W 4bolt block 4.00 stroke crank 4.125 bore super Vic intake flat top pistons, 13.5:1 compression, 1000 cfm carb 2.00 primary long tube headers , solid roller cam, 1.6 shaft mounted roller rocker arms 3/8 .135 wall pushrods 220 AFR heads
Cam specs .720 intake .740 exhaust
Duration @ .050 intake 272 exhaust 280
108 lobe seperation
Will this combo make 750 plus hp ?
Thanks Whitefield
108 lobe seperation
Thanks Whitefield
whitefield- Posts : 2244
Re: Big bore Windsor build
Should be in the ballpark, depends on who's doing the building
dfree383 wrote:Should be in the ballpark, depends on who's doing the building
Well unfortunately that be me ! Lol
What oil pan are you going to use on this?? Front sump, or rear sump??
BBFTorino- Posts : 999
BBFTorino wrote:What oil pan are you going to use on this?? Front sump, or rear sump??
Canton double sump 7qt drag racing pan
https://www.cantonracingproducts.com/cgi-bin/commerce.cgi?preadd=action&key=13-672SV
I bought a Canton pan, P/N 15-694 and it does not fit my block. I have the Ford Racing SVO block with 4 bolt main caps on 2 thru 5.
It will not clear the rear cap, its too large!!. The way the pan curves around in the rear, it was hitting the cap, and the whole pan needs to move forward about 3/8" of a inch. But this pan fits in the chassis, so I decided to cut it and modify it.
Basically, the whole pan is too short and I needed to extend the back "wall" of the pan. Im still working on it.
BBFTorino wrote:I bought a Canton pan, P/N 15-694 and it does not fit my block. I have the Ford Racing SVO block with 4 bolt main caps on 2 thru 5.
Canton also makes that pan, (a different part number), for a Ford Performance BOSS and Dart blocks which will clear the side of the main caps and the rear cap ... their regular pan will not.
Yeah, I figured that out after I started cutting!! LMAO
Oh well, its an easy mod to do and once its done, I can move on to the next step.
I wish I knew how to post pics.
I think 700 will be real close. That extra 50 gonna take some some attention to detail! Lol. Good luck on build should run good. What are you putting it in?
lance flake- Posts : 142
lance flake wrote:I think 700 will be real close. That extra 50 gonna take some some attention to detail! Lol. Good luck on build should run good. What are you putting it in?
I plan on putting it in the 64 fairlane in my avatar. I would really like to get 750 at the flywheel! Thanks
HEYYYYYYY.............. I got the same thing got a smaller cam though. ive got scat/probe guts in mines...
torino501- Posts : 417
AFR 220’s
I kinda thought so
» BBF engine build in April's MM&FF....557 stroker vs 427 blown Windsor. Interesting read
» Cometic 4.400 bore gaskets on 4.390 bore block ,will it work ?
» E4OD build reccomendations for a 79 f150... first transmission build, no ideah what I'm doing
» Sold
» 408 Windsor
» Sold
» 408 Windsor
