Cometic 4.400 bore gaskets on 4.390 bore block ,will it work ?
Cometic 4.400 bore gaskets on 4.390 bore block ,will it work ? Empty Cometic 4.400 bore gaskets on 4.390 bore block ,will it work ?
Post  10SHOTS March 21st 2011, 12:29 pm
will Cometic 4.400 bore gaskets work on 4.390 bore block using tfs street heads without any problems?
thanks
10SHOTS
10SHOTS
Cometic 4.400 bore gaskets on 4.390 bore block ,will it work ? Empty Re: Cometic 4.400 bore gaskets on 4.390 bore block ,will it work ?
Post  dfree383 March 21st 2011, 12:40 pm
what heads? Have you checked for combustion chamber overhang?
Post  10SHOTS March 21st 2011, 12:53 pm
dfree383 wrote:what heads? Have you checked for combustion chamber overhang?
trickflow street , have not checked cause heads still on the engine .
10SHOTS
10SHOTS
Post  dfree383 March 21st 2011, 12:56 pm
As long as the chambers are inside the bore they should work fine.
its not desireable to have the gaskets hanging inside the chambers or hanging over a chamfer on the top of the bore too.
Post  dfree383 March 21st 2011, 1:08 pm
Lem has small bore ones instock that will work fine if your looking for them.
Post  Lem Evans March 21st 2011, 1:35 pm
They'll work but I'd use the 4.5" bore gaskets if you haven't already got them.
Post  342g March 22nd 2011, 7:39 pm
Lem, have you got a 35-38 thousand head gasket set 4390 bore? if so I need one.
342g
342g
Post  Lem Evans March 22nd 2011, 7:51 pm
No....I can get them. 4.390" cyl. bore or 4.390" gasket bore? Just put a 4.500" bore gasket on it ....in my opinion.
Post  342g March 22nd 2011, 8:05 pm
Lem Evans wrote:No....I can get them. 4.390" cyl. bore or 4.390" gasket bore? Just put a 4.500" bore gasket on it ....in my opinion.
You got them in stock?
342g
342g
Post  Lem Evans March 22nd 2011, 8:15 pm
I thought I said ........no......meaning......no stock Laughing
Post  342g March 22nd 2011, 8:21 pm
I'm sorry I thought you meant you had the 4500 in stock, my bad.
342g
342g
