small block ford heads
whitefield
larry552
has anyone herd of the Scorpion Aluminum Heads or are they pro comps
I found this on google for them I just haven't herd of them http://scorpionproductsinc.com/index.php?main_page=product_info&cPath=5_66_241&products_id=322
Re: small block ford heads
I never heard of them
larry552- Posts : 335
Nope I can't say that I have!
whitefield- Posts : 2244
I getting ready to buy a set of aluminum heads for my 69f100 it going to be a small budget build might just save a little more on it and buy some Trick Flow heads for it just going to be a freshen up build with new heads and custom cam. Not looking to make any big hp just something around a 300 to 350 hp 351w with a little more tq.
69F100 wrote:I getting ready to buy a set of aluminum heads for my 69f100 it going to be a small budget build might just save a little more on it and buy some Trick Flow heads for it just going to be a freshen up build with new heads and custom cam. Not looking to make any big hp just something around a 300 to 350 hp 351w with a little more tq.
Unless you want to buy aluminum heads a set of cast iron GT40 or GT40p heads with 9.5:1 and a custom hyd or hyd roller cam will get you 350 flywheel hp.
Just from my experience But nothing wrong with budget build and those scorpion heads !
Post your build and good luck with it !
i looked at the eddy e street heads at Summit Racing today almost bought them but backed out they did not look much more than a gt40 aluminum head.
What's the old saying? You get what you pay for? AFR or Edelbrock are probably your best bet. Anybody who won't put their name on a casting sure can't be proud of the workmanship, or lack of it.
pmrphil- Posts : 171
69F100 wrote:has anyone herd of the Scorpion Aluminum Heads or are they pro comps
Nobody here seems to actually know about them so, buy 'em and you'll know; then tell us all what you find because you'll be the experienced one..
I had hope that we could find out about some brand heads I knew nothing about.
Your head choice should depend greatly upon whether or not you want to spend more money on a "stud" rocker arm valve train vs. an O.E.M. type "bolt down" set-up used from Ford since the early 80's.
get the afr 165 they will do what you need
That's a big runner. If you want a low maintenance street setup go with the AFR, E'brocks or the FRPPs that use the factory style pedestal rockers. Bolt 'em down and go...
jbozzelle- Posts : 3705
If they are a no name brand, they are Chinese!!
BBFTorino- Posts : 999
BBFTorino wrote:If they are a no name brand, they are Chinese!!
"Chinese" does not necessarily equate to bad quality castings although most of the hardware is.
rmcomprandy wrote:69F100 wrote:has anyone herd of the Scorpion Aluminum Heads or are they pro comps
I am waiting on a reply from them I emailed them asking what valves and springs and who made the castings but haven't gotten a reply back. I am going with a stud mount going back with a solid lift cam flat tappit custom cam from you. When I figure what heads I am getting debating on the Eddy E streets or the Ford X307. Trick Flow I have to change Pistons from what I have read
69F100 wrote:rmcomprandy wrote:69F100 wrote:has anyone herd of the Scorpion Aluminum Heads or are they pro comps
You don't want the Ford "X" heads then because they use "bolt down" type rockers; not stud mounts.
Personally, in your situation, I would use the 222 series Profiler heads but, they are a race quality head with CNC'd combustion chambers, 63cc and valve jobbed for 2.055" & 1.600" Valves and bowl blended. NOT an inexpensive head though and NOT available as complete heads.
Lower priced:
I have used the Edelbrock #60259 "Performer RPM" heads with 60cc chambers having great success on an Engine Masters 414 engine with .060" thick SCE composition head gaskets and ported like the Edelbrock E-CNC 185 #79259 heads.
rmcomprandy wrote:69F100 wrote:rmcomprandy wrote:69F100 wrote:has anyone herd of the Scorpion Aluminum Heads or are they pro comps
Lower priced:
Thanks Randy for the info right now my 351w it is a 74 model block with the replacement factory 69 model pistons .030 over my brother bought for his engine for a 69 Mach 1 mustang he had. Not sure what dish is on them but it was not as much as the factory piston I took out. I built this engine about 12 years ago I have 70 model 351w heads with a old lunati 292 .512 lift cam. Heads is in need for some valve guides and freshening up in stead of having the old heads freshened up going to put that in a new set of aluminum heads for it.
» New 57 Ford Project Should we go big block or small block? Pics added
» SMALL BLOCK HEADS
» Small block ford parts
» WTB E5AE small block heads
» Kaase C5 small block heads
» SMALL BLOCK HEADS
