Cam for 351W project?
Cam for 351W project? Empty Cam for 351W project?
Post  Green 72 January 4th 2018, 6:21 pm
Looking for advice for cam for Ranger project.85 Ranger,early Bronco axles,4.10 gears,35 tires,M5OD-R2 5 speed,205 transfer case and 69 351W 4BL.Motor is factory 4BL that has been bored .030 over and has flat top pistons has C9 heads that have been ported,roller tip rockers,eddy performer RPM,650 Holley and eddy 5022 cam.Have lifters,spyder and hold downs for hyd roller conversion.Was looking for advice stay with cam I have,different FT hyd or change to a hyd roller.Truck will be mostly just cruiser.
Green 72
Cam for 351W project? Empty Re: Cam for 351W project?
Post  rmcomprandy January 4th 2018, 7:19 pm
Green 72 wrote:Looking for advice for cam for Ranger project.85 Ranger,early Bronco axles,4.10 gears,35 tires,M5OD-R2 5 speed,205 transfer case and 69 351W 4BL.Motor is factory 4BL that has been bored .030 over and has flat top pistons has C9 heads that have been ported,roller tip rockers,eddy performer RPM,650 Holley and eddy 5022 cam.Have lifters,spyder and hold downs for hyd roller conversion.Was looking for advice stay with cam I have,different FT hyd or change to a hyd roller.Truck will be mostly just cruiser.
What year is the BLOCK ..."
That hydraulic roller stuff won't work on early non-roller pre-"93 blocks without an appropriate Small Base Circle special camshaft.
Use the Lunati "Tie Bar" hydraulic roller lifters and a normal, regular base circle camshaft can be used.
Post  Green 72 January 4th 2018, 7:49 pm
Randy it is a 69 block.Randy I used the Lunati cam you suggested for my 466. Thanks for the help.
Green 72
