new heads!
NITROUS FORD
new heads!
just seen and article about the new pro-18 heads for bbf 18 bolt blocks motors. they look like some pretty nice heads. just wondering what intake can be use with those heads!
int cfm was 490 ex cfm 354. these would be great out the box over my a460 heads if they bolt up to the tfs a460 r intake manifold!
NITROUS FORD- Posts : 63
Re: new heads!
What article?
windsor- Posts : 1167
Re: new heads!
They are from Carol Carter and are the old Thor heads from BT
Nothing interchanges directly with A460 heads the are closer to C460 stuff but not exactly
Re: new heads!
NITROUS FORD wrote:just seen and article about the new pro-18 heads for bbf 18 bolt blocks motors. they look like some pretty nice heads. just wondering what intake can be use with those heads!
Fabricated Intake Manifold
Re: new heads!
rmcomprandy wrote:NITROUS FORD wrote:just seen and article about the new pro-18 heads for bbf 18 bolt blocks motors. they look like some pretty nice heads. just wondering what intake can be use with those heads!
Or you can build some adaptors similar to what Charlie sells for A460 manifolds on C460 heads.
BT did have a 2 piece cast manifold for the Thor heads but its hard to find and I'm not sure C&C is making them to? Would have to call and ask Carol
Re: new heads!
http://www.survivalmotorsports.com/images/Blue_Thunder_43_Intake_front_corner_small.jpg
Re: new heads!
dfree383 wrote:http://www.survivalmotorsports.com/images/Blue_Thunder_43_Intake_front_corner_small.jpg
thanks for the reply!
Re: new heads!
Isn’t that the SBF intake?
Re: new heads!
windsor wrote:Isn’t that the SBF intake?
It could be they look almost identical but ones a lot bigger
Re: new heads!
https://i.servimg.com/u/f62/13/31/98/41/screen10.jpg
https://i.servimg.com/u/f62/13/31/98/41/screen11.jpg
BBF552- Posts : 34
Re: new heads!
This is the Thor intake I have for the big block
BBF552- Posts : 34
Thor intake
BBF552 wrote:This is the Thor intake I have for the big block
That one may work on Carol's head depending on the bolt pattern. Bischoff used one on a RCV build I've seen. Some fab work needed on that one.
Gary Blair- Posts : 221
Re: new heads!
BBF552 wrote:
jasonf- BBF CONTRIBUTOR
Re: new heads!
got it from the drag illustrated magazine!
Re: new heads!
http://www.besracing.com/cylinder-head-and-intake-packages/cylinder-heads/ford/bbf/bes-bbf-c-and-c-motorsports-pro-18
» A429 Heads VS Dove-c Heads
