Pushing water out of radiator?
STR-LGL-70
capncruncher1965
Guys have a brand new 545 in a 96 mustang and its got a alluim raditor it keeps pushing water out bad with the cap off. Water will go up then down then start shooting out the top. Did the same thing with the 466 in it. This motor is all new water pump is manual.factory electric fan and shroud. Thermostat is gutted out. We just cant figure it out. Thanks
capncruncher1965- Posts : 131
Re: Pushing water out of radiator?
Have you done a compression test?
STR-LGL-70- Posts : 223
Not yet
Not yet motor runs great but we are going to check the cylinder pressure tomorrow.
What pressure cap?
stanger68- Posts : 500
Put the cap back on and watch the temp.
cletus66- Posts : 865
Could be the top hose is higher than the radiator trapping air. That can cause all sorts of problems.
rmk57- Posts : 176
rmk57 wrote:Could be the top hose is higher than the radiator trapping air. That can cause all sorts of problems.
You are correct. When I filled my 460 powered 81 Mustang's radiator up, I jacked the front end way up to get the air out, and then I never took the radiator cap off again....seriously, I should probably look in there once in a while...
Sorry I missed the cap off part.
16lbs cap
The engine is higher than the top of the radiator. Did not think about that but there's no way to raise the radiator up any higher. Anything we can do to compensate this?
Old motor same problem
Other motor did have a blowed head gasket. Pretty sure this one does not its not got over 200 degrees
capncruncher1965 wrote:The engine is higher than the top of the radiator. Did not think about that but there's no way to raise the radiator up any higher. Anything we can do to compensate this?
Can you fit a remote radiator cap in the upper hose?
https://www.google.com/search?q=remote+radiator+cap&rlz=1C1CHZL_enUS748CA748&oq=remote+radiator+cap&aqs=chrome..69i57.4174j0j7&sourceid=chrome&ie=UTF-8
jasonf- BBF CONTRIBUTOR
capncruncher1965 wrote:Guys have a brand new 545 in a 96 mustang and its got a alluim raditor it keeps pushing water out bad with the cap off. Water will go up then down then start shooting out the top. Did the same thing with the 466 in it. This motor is all new water pump is manual.factory electric fan and shroud. Thermostat is gutted out. We just cant figure it out. Thanks
if its a hi flow pump it does push water out with cap off, whats it do with the cap ON?
one of MINES A GUSHER with the cap off, also depends on how the rad was made,and where the cap location is
BOSS 429- Posts : 2372
jasonf may have a solution, I'd try it anyway. I know the early 60's FE Galaxies had a surge / expansion tank from the factory for the same problem your having.
rmk57- Posts : 176
I hope for your sake, it is something simple.
It could be combustion pressure migrating into the water jacket, if there is a porous place anywhere within an area which sees cylinder presure.
High flo pump
Thats our problem. Pump is high flo dam didn't think about that.going to run it some tomorrow will give a update tomorrow night. Really want to thank all you guys for trying to help us out.Best dam website ever!!!!
Got it fixed
Finally got it fixed. Took out the AC condenser got the fan on high speed filled it with water dam thing ran cool. Thanks guys for all your replys.
» How much horsepower am I pushing?
» radiator cap
» Switched from mech water pump to Moroso electric water pump
» 460 Water Pump Crossover Tube that goes in the Intake to the Water Pump?
» Water tank in trunk.
» radiator cap
