4.6 dohc out of a lincoln continental
Hello all. I have a 4.6 dohc engine out of a 98 continental. I am looking for a bell housing plate to convert it to a regular small block pattern. Any help would be great.
Jwshanks- Posts : 9
Re: 4.6 dohc out of a lincoln continental
What transmission are you trying to mate to?
jasonf- BBF CONTRIBUTOR
4.6 bell housing
I was planning on using either a small block c6 or a manual trans for the same. I have looked around and nobody makes an adapter. Short of building my own adapter plate or bell housing I'm at a loss at what to do.
Jwshanks- Posts : 9
Performance Auto makes a bellhousing for a C4 to mod motor. WTH would you want a C6 for?
http://www.performanceautomatic.com/products/parts-and-accessories/bellhousings-and-rings/pro-fit-bellhousings.html
LMR sells a whole kit.
https://lmr.com/item/PAI-SS26106/1996-2012-46L-50L-Modular-C4-Street-Smart-transmission-Kit
when you say manual are you talking junky old 4 speed manual? Any late model 5 speed from a mod motor would work.
mod motor trans adpapter
I was going to use a c6 because I have one. And the 4 speed is an old one at that. Going to put this in a rock crawling buggy so weight is not much of an issue. thanks for the info, this is really helpful. The only reason I have this motor is it was cheap. 40 dollars cheap.
Jwshanks- Posts : 9
mod motor trans adapter
This motor does not have the standard mod motor bell housing. It came out of a front wheel drive car. Hence the need for an adapter
Jwshanks- Posts : 9
Jwshanks wrote:This motor does not have the standard mod motor bell housing. It came out of a front wheel drive car. Hence the need for an adapter
I was wondering about that. That's why it was only $40. lol
Call Keith Fulp.
I bet he can make you one.
http://www.keithfulpmotorsports.com/
res0rli9- BBF CONTRIBUTOR
» 460 in lincoln continental Mark iv rocker type
» WANTED, CONTINENTAL MARK VIII BUCKET SEATS
» C9VE engine from 69 Continental -- Have questions about where to go with this engine
