Callies compstar rods
I was planning to order Eagle 67003DL19 rods, but just saw the Callies CPI-B6700ES3B9AH. It is a few hunderd dollars more, but is it a better rod? Both have L19 bolts.
Re: Callies compstar rods
Callies would like you to think so. "I" don't see a $200 difference in the two sets.
gt350hr- Posts : 662
I have had 2 engines through the shop with callies rods - both engines had rods out of round - I wonder if it has to do with the amount of torque they require. Both eagle and callies had the same bolts, eagle is 79 lbs w/moly and callies is 92 lbs w/CMD3 lube, both called for approx. the same stretch. Didn't like the callies myself, opinions will vary.
pmrphil- Posts : 170
» Callies magnum 4.750 crank
» Oliver or Callies Ultra rods
» Aluminum vs eliminator callies vs bryant or winberg
» callies crank
» New Callies Magnum 4.75 crankshaft
» callies crank
