Mod Motor Trans Adapter
Does anyone sell an adapter to use a Mod Motor pattern trans behind a 460? I want an Overdrive transmission in my 63 Galaxie but the trans tunnel is too small to use an E4OD. Pretty sure a late model 4R70W will fit and the mod motor pattern is more readily available.
dbshelton- Posts : 48
Re: Mod Motor Trans Adapter
yea a guy in ham lake mn. say you have to rotate the tranny slightly.....zbob
zbob- Posts : 271
Thanks, but Bendtsen's doesn't make an adapter for a Modular-pattern transmission on a 460.
Why not us an AOD and put the 4r70w guts in it? They make bellhousings for that.
https://transmissioncenter.net/shop/adapter-to-install-an-aod-overdrive-transmission-on-a-460-big-block-ford-motor/
https://www.summitracing.com/oh/parts/jpt-92454-aod/overview/make/ford
jasonf- BBF CONTRIBUTOR
Thanks. I have considered that. Just not sure which way to go yet. Using a 6R80 would be cool, but Mod Motor pattern only. Also considering taking the built E4OD I have and moving all of the guts into a smallblock case with an adapter.
Just trying to see what's out there. It may even be easier to cut out and rebuild the tunnel. I know I am capable of doing that.
You could do a C4/C6 and do a Gear vendors. It would probably have similar cost in the end because AOD's are so expensive and C4/C6's are not.
dbshelton wrote:Thanks. I have considered that. Just not sure which way to go yet. Using a 6R80 would be cool, but Mod Motor pattern only. Also considering taking the built E4OD I have and moving all of the guts into a smallblock case with an adapter.
Does your car have a console? The 6R80's are huge.
No console. Just bucket seats I swapped in from a 63 XL.
I will probably just keep the C6 in it for now.
jasonf wrote:Why not us an AOD and put the 4r70w guts in it? They make bellhousings for that.
A 4r70w from a 4.2l v6 (truck or van) will have the SBF bellhousing pattern. So you should be able to use the AOD adapter to mate it to a 460. I have used the v6 4r70w trans behind a SBF, never used the adapter though.
Jess
Mustang-junky- Posts : 438
problem with gear vendors is you still have converter slippage on the hiway with the modern trans you have a lock up converter .
wayne
wayne
jasonf wrote:You could do a C4/C6 and do a Gear vendors. It would probably have similar cost in the end because AOD's are so expensive and C4/C6's are not.
wayney- Posts : 187
» 4.6 dohc out of a lincoln continental
» TKO.Trans holdup with.a.557 N/A motor
» 460 motor /trans
» 62 Ford F100 Unibody
» Motor/trans combo for sale
» 460 motor /trans
