Track Time
Track Time
Heading to the track Friday night to see how the Ranger does been almost 2 years I will see how it does now with the new frontend and Ron's toilet. hoping for some high 5s in the 1/8 but will run it out the 1/4 to see what it will do in the 1/4 also.
Re: Track Time
Good luck on running the times you want to run and be safe!!!!
![Smile](https://2img.net/i/fa/i/smiles/icon_smile.gif)
Mark Miller- Posts : 1946
Re: Track Time
Good luck. Post some time slips. I lwould ove a report on the change
To the toilet.
To the toilet.
t-bird racer- Posts : 192
Re: Track Time
Well found out I can do a 106mph burnt all they out the 1/8 on the 1st pass
2nd pass a Vett oiled the track in my lane after they cleaned at the track I did a John Force burn out hoping to soften the tires up a little bit more. Let off the brake right at or just a little after 60' started shaking the tires bad go out of it then got back in no traction blew the tires did a little fish tail let out of it loaded it up. I think need a set of tires going to get it back in my shop put back on jack stands check everything good 1st.
Re: Track Time
[quote="t-bird racer"]Good luck. Post some time slips. I lwould ove a report on the change
To the toilet. [/quote
If I still had the 1050 on it I don't think I would have had traction problem. The toilet made a big difference it is like a whole different engine now. Will be ordering some new slicks and try again
» Track report
» Post your best track time
» Track time (Pics) & Video
» THANKS TO............. THE TRACK and
» Back Together Again *(Update) TNT 7-2-10
