Oil pump and pick up tube question
I have a front sump Canton 15-750 oil pan with the matching pick up tube 15-751 tube
And melling oil pump
https://www.summitracing.com/parts/ctr-15-751
My question is just holding the pickup tube to the oil pump the screened pickup area sits at a angle is that gonna be ok? Just looks kinda weird. Thanks
duff429- Posts : 202
Re: Oil pump and pick up tube question
There are different versions of pumps for BBF's, and they offer 3 (I believe) different mounting angles - sounds like you might have either the wrong pickup or the wrong pump. Check with Canton directly (or online) and verify which pump/screen you should have.
pmrphil- Posts : 171
I have the melling m84dhv pump
Looks like I need the M-84BHV pump. The tube has a bolt on area at a angle. Guess I got another pump for another build now
ITS NORMAL to be at a little angle
BOSS 429- Posts : 2372
The D pump is the truck/van style normally used with the rear sump pan,the B pump is the car CJ/PI style normally used with the front sump pan,although the D pump can be used with a front sump pan with the appropriate pickup.I've heard that the D pump has some attributes that make it a superior pump but I don't know what those are,it seems to be recommended as the preferred pump.
427John- Posts : 86
» Need help finding correct oil pump pick up tube
» External oil pump -- Converting a conventional wet sump oil pan
» Oil Pump Pick Up for Front Sump Pan and Kaase Pump
» Rod bolts hitting pick up tube
» mounting the pick-up tube to the main cap.
