Quick Question 2
Quick Question 2
I received my arp carb bolts today, can someone tell me why there are 3 studs aprox. 1.7 long, (one with a hole in it), and one is aprox. 2.05 long?
Now I know the hole is for a safety wire, but should at least all 3 1.7's have a hole? Or all 4?
And what's with one long one? I can see 2, cause with the cable plate and spring return.
Any ARP dealers on here?
ARP Carb Studs 300-2424 (no spacer)
can't send pics yet.
rbro460- Posts : 102
Re: Quick Question 2
from summit site
Notes:
Pro Series studs are drilled for sealing wire. They're designed to fit Moroso dual throttle return spring brackets, which mount using one carburetor bolt hole. Fits applications without a spacer.
Notes:
bosshoss- BBF CONTRIBUTOR
bosshoss wrote:from summit site
Notes:
bosshoss, Thank you for the comment, but pics would help.
Anyone use these bolts on there car? Pics of carb and bolts?
rbro460 wrote:bosshoss wrote:from summit site
Notes:
bump
» Quick question.
» Quick question
» quick SFI Jacket question
» quick compression question...
» Quick valve spring question
» Quick question
