Quick question.
DFI429
bb429power
Quick question. Empty Quick question.
Post  bb429power August 15th 2010, 1:40 pm
What should I torque my rod bolts to? With moly?
bb429power
bb429power
Quick question. Empty Re: Quick question.
Post  billandlori August 15th 2010, 1:46 pm
Are they stock bolts or ARPs?
Bill
Post  bb429power August 15th 2010, 2:02 pm
ARP's on stock car rods.
bb429power
bb429power
Post  whatbumper August 15th 2010, 3:39 pm
Do you not have the ARP spec sheet? I would call them or look at their website.
Post  bb429power August 15th 2010, 4:00 pm
I'll have to email the guy on what bolts they are, i don't think I have the ARP sheet with me.
bb429power
bb429power
Post  DFI429 August 15th 2010, 6:11 pm
This is something I've seen strong opinions go both ways... I'd like to see Lem & other assembly hErOs chime in.. Cool
Torque or stretch gauge measurement? Question Question Question
DFI429
DFI429
Post  Nevs August 15th 2010, 6:16 pm
ARP says for the pn 155-6003, which is a stock rod 8740 bolt, .0063" stretch or 50 foot pounds.
Post  bb429power August 15th 2010, 6:24 pm
No stretch gauge. How am I supposed to check the angle though? Use a degree wheel or what?
Nevs, are those 50 lbs at a certain angle or just in general?
Thanks for helping.
bb429power
bb429power
Post  DFI429 August 15th 2010, 6:28 pm
Nevs wrote:ARP says for the pn 155-6003, which is a stock rod 8740 bolt, .0063" stretch or 50 foot pounds.
Yes, I realize the two are available... I was asking the pros which tightening method they prefer, or maybe a combination of both?!?? Some guys prefer the stretch measurement exclusively, some the opposite...
DFI429
DFI429
Post  Nevs August 15th 2010, 7:02 pm
bb429power wrote:No stretch gauge. How am I supposed to check the angle though? Use a degree wheel or what?
Thanks for helping.
Straight torque wrench reading. General consensus is the stretch gauge is the best method. However, torque wrenches were used for years and seemed to do just fine in general purpose overhauls. No doubt the stretch gauge is probably the most precise. Unless this is a high end build ( and it obviously isn't given the stock rods), I'm sure a torque wrench will suffice.
Post  schmitty August 15th 2010, 7:31 pm
I'm no expert engine builder, but I've overhauled many, and the regular old torque wrench method seemed plenty sufficient. There is no rocket science needed here. Cool
Post  bbf-falcon August 15th 2010, 8:51 pm
If you tighten a ARP rod bolt w/motor oil 63 ft.lbs. you should be fine imo.
Post  cool40 August 15th 2010, 10:25 pm
i'd want to know too if i were you.i went through this a few weeks ago with wsb oliver bolts.i had to get a tq/angle tool for them and go 42*from 55lbs i think it was and didnt realy like that kinda tq on a 7/16 bolt but i'm no HeRo. Laughing
Post  bb429power August 15th 2010, 10:36 pm
so have the rod journal straight down (or pointing up since the engine is turned over) and tighten to 50 without moly? I know I need moly for my head bolts, but I'm not sure about the rods.
As Austin Powers says, moly moly moly moly moly!!!
bb429power
bb429power
Post  bb429power August 15th 2010, 10:45 pm
While I'm at it, the oil sending unit is in the right place isn't it? It was in that spot when I got it but I want to double check that its supposed to be there. I read that that spot is for the dry sump oil return.
Quick question. P8030114
bb429power
bb429power
Post  Nevs August 15th 2010, 10:52 pm
bb429power wrote:While I'm at it, the oil sending unit is in the right place isn't it? It was in that spot when I got it but I want to double check that its supposed to be there. I read that that spot is for the dry sump oil return.
The 50 ft pounds is with ARP lube on the threads.
Who told you or where did you read that the spot in question is a dry sump return? It's not,for one thing it's not nearly large enough and how would you return oil to a pressurized gallery? Laughing I'd throw that book away. Idea
Post  cool40 August 15th 2010, 10:58 pm
it's not a dry sump return but it is the place for a sender/gauge.
Post  bb429power August 15th 2010, 11:01 pm
http://jonkaaseracingengines.com/products/blocks/eliminator-blocks/64-eliminator-blocks.html
Its under HP Sportsman, I read it wrong though. It says its an oil "feed". I thought I had it in the right place but my dad kept pushing the issue about it being in the front (like the windsors and all). Thanks for the help guys, I'll finish the others tomorrow, then the oil pump will go on. That's about all I can do unless I put the cam and chain on.
bb429power
bb429power
