NMCA Classes
NMCA Classes
I'm looking at running at Norwalk for the Cobra Jet reunion. They arent having a Pro bracket race. So I look into the rules to get into the NMCA to find a class. I cant find one that I see that a non-NMCA member can run. If you are a member please help.
My car is a tube chassis 69 Mustang, ladder rear/M2 front, 580 NA BBF with P-51 heads on E85, its plated for the street but has a 12 pt cage, has big tires but that can change.
Ive got a message into the NMCA contact already.
If I'm screwed just say so.
Dave De- Posts : 797
Re: NMCA Classes
Dave De wrote:I'm looking at running at Norwalk for the Cobra Jet reunion. They arent having a Pro bracket race. So I look into the rules to get into the NMCA to find a class. I cant find one that I see that a non-NMCA member can run. If you are a member please help.
Can you run Open Comp?The only bad thing about that class though is qualifying is based off of reaction time not ET!!
Mark Miller- Posts : 1958
Re: NMCA Classes
Mark Miller wrote:Dave De wrote:I'm looking at running at Norwalk for the Cobra Jet reunion. They arent having a Pro bracket race. So I look into the rules to get into the NMCA to find a class. I cant find one that I see that a non-NMCA member can run. If you are a member please help.
I can run that class but I havent done well with a pro tree. At least its a .500 tree.
Re: NMCA Classes
I think Mark nailed it.... Open Comp FTW!
Time to get the practice tree out and work it like a pickpocket at a jewelry convention!
Re: NMCA Classes
If you can hit a .500 Sportsman tree then a .500 pro tree is no different unless you are anticipating the light. I had to lower my launch rpm and slow down the transbrake dump on my car in order to not go red on the .500 pro tree.
D. Sea- Posts : 2768
Re: NMCA Classes
The last time I had a Pro Tree experience was a .400 light and I was way late. I didnt know I was in the quick 8 program until minutes before it started. I couldnt adjust my button or bypass the TB relay.
I will practice and see what I can do if Im back together in time to run.
