Foxbody SS question
bigblokfoxs
Foxbody SS question
What is the fastest anyone has been on welded up factory torque boxes ? When is the aftermarket boxes needed ?
Torque Box question
I will get this started..I am sure there are better numbers out there.
With stock unmodified torque box configuration, to date my car has run 5.80 1/8th, (9.10 1/4). Short time 1.30.
557
C4 with Brake @ 4K
28" tire
3.73 gear
3050#
Greg C.
557
C4 with Brake @ 4K
28" tire
3.73 gear
3050#
Greg C.
bigblokfoxs- Posts : 3
Re: Foxbody SS question
nice numbers , what cylinder heads ?
FOX BODY SS
Kaase P51's with a little touch up. CR is 14.25
I've been 5.08 and 5.09 with a 1.18 60ft. In 1/8 mile. 580in A-head motor on a single fogger I have been thinking about upgrading to the aftermarket lowers. In your case with a new fresh build I probably install the aftermarket stuff.
larry552- Posts : 335
bigblokfoxs wrote:Kaase P51's with a little touch up. CR is 14.25
Nice
larry552 wrote:I've been 5.08 and 5.09 with a 1.18 60ft. In 1/8 mile. 580in A-head motor on a single fogger I have been thinking about upgrading to the aftermarket lowers. In your case with a new fresh build I probably install the aftermarket stuff.
what have you done to your torque boxes ? weld the seems ? added material ?
The uppers are reinforced because they were pulling apart and the lowers are tacked with the reinforced kit added
If your uppers are not abused I'd recommend welding them and running the support tubes from the inside of the upper boxes forward to the main hoop.
But if you're looking for the maximum in adjustability of the upper arms (think ride height here) then just go with the aftermarket stuff and be done with it...
jbozzelle- Posts : 3705
Going fast on the stock torque boxes isn't the problem, having them last is.
Weld, Plate and sandwich bolt them up and do Like John suggested by adding bars from the cage to the mounting points.
Here's what you do Nick...
Mock up at ride height and see what the intersect points look like and if they'll work with the power you plan to make.
jbozzelle wrote:Here's what you do Nick...
not understanding about what you are saying ??
The rear suspension bars in a Fox like a certain ride height to get the correct instant center (IC) and let the rear suspension function properly. Raising or lowering the ride height affects the IC.
If I was building one with stock suspension and a high HP/torque engine I'd make sure my ride height would put the IC where it needs to be and let that determine the money that needs to be spent...
jbozzelle wrote:The rear suspension bars in a Fox like a certain ride height to get the correct instant center (IC) and let the rear suspension function properly. Raising or lowering the ride height affects the IC.
understand, getting impatient , needs this done asap .... but i would rather do it once and put the right stuff under the car .
Do you guys have an opinion on whos upper and lower boxes are the best ?
TeamZ are good. I run UPR on my car. Baseline suspension seems to have some nice uppers that I want to try.
I’ve used our stuff in the past and have some grannitelli stuff going on my stocker, but I do have certain rules to follow
dfree383 wrote:I’ve used our stuff in the past and have some grannitelli stuff going on my stocker, but I do have certain rules to follow
"our stuff" ????
I'm looking hard at the Wild Rides upper and lower S-Boxes' looks like some good parts, and you're right do it once and be done. It's a lot easier to do the work while the cars apart than to have to tear it up later
https://wildridesracecars.com/shop/ford/new-lower-s-box-adjustable-lower-torque-box-replacement-kit/
https://wildridesracecars.com/shop/ford/new-s-box-adjustable-upper-torque-box-replacement-kit/
Mike R- Posts : 1381
bruno wrote:dfree383 wrote:I’ve used our stuff in the past and have some grannitelli stuff going on my stocker, but I do have certain rules to follow
"our stuff" ????
Other.... Sorry, Fat Finger Typo
Mike R wrote:I'm looking hard at the Wild Rides upper and lower S-Boxes' looks like some good parts, and you're right do it once and be done. It's a lot easier to do the work while the cars apart than to have to tear it up later
yes i had looked at there stuff.
» jw bell on glide foxbody question
» 429 in foxbody
» oil pan for bbf foxbody
» complete 9 inch for foxbody
» 429 in foxbody
