Jon Kaase SR71 Cylinder Heads
+63
mitch huested
away
torino501
427John
CDMBill
Carbguy
SandHillsHillbilly
Lukesportsman
Ol'Blue77
Mikejc
6t6mustang
MidnightbluS10
psfracer
terryk105
BBF552
ED468
fordsrgrt
nitrous.f
Carl
boss9coupe
nuclearcobra
Stimie
Mark O'Neal
cobrakid8
Coupe Devil
STR-LGL-70
DGS
Gary Blair
glenevans
litshoot
jonkaase
68galaxie
JBR-3
nascar429
wayney
enginetech
67 posters
Page 8 of 12
Page 8 of 12 • 1, 2, 3 ... 7, 8, 9, 10, 11, 12
Re: Jon Kaase SR71 Cylinder Heads
Lem Evans wrote:c.evans wrote:BBFTorino wrote:How old are the C heads? When did they appear on the scene?
I think the C-460 heads appeared in 1994. At least that's date on the 4 pages of instructions that came with the heads.
Charlie
1994 is correct.
Wow, 10 years after the A heads. Quite an impressive improvement in that amount of time though.
68formalGT- Posts : 865
68formalGT wrote:Lem Evans wrote:c.evans wrote:BBFTorino wrote:How old are the C heads? When did they appear on the scene?
Charlie
1994 is correct.
The "C" head was merely a C3 small block "Yates" NASCAR platform cylinder head made larger to fit the big block engine size.
rmcomprandy wrote:68formalGT wrote:Lem Evans wrote:c.evans wrote:BBFTorino wrote:How old are the C heads? When did they appear on the scene?
Charlie
1994 is correct.
As well as it worked I wonder why they never made a Cleveland head larger to fit a big block? Was it because the Cleveland was banned in NASCAR?
68formalGT wrote:rmcomprandy wrote:68formalGT wrote:Lem Evans wrote:c.evans wrote:BBFTorino wrote:How old are the C heads? When did they appear on the scene?
Charlie
1994 is correct.
You could say that the Ford E-460 Pro Stock head was a "Cleveland head"for a big block. While it was a porters head, it had the basic construction for a canted valve head. Probably more accurately, we could go back in time and call the TFS A-460 heads a "Cleveland head" for a big block.
Charlie
c.evans- BBF VENDOR SPONSOR
c.evans wrote:68formalGT wrote:rmcomprandy wrote:68formalGT wrote:Lem Evans wrote:c.evans wrote:BBFTorino wrote:How old are the C heads? When did they appear on the scene?
Charlie
1994 is correct.
Charlie
Wasn't the Cleveland valve angles around 8* with a 3* side angle where the A460 is more around 13* and 4*? How much better performance would there be with the Cleveland angles in the A460 head or more like a Profiler 221 set up to take the A460 intake and exhaust?
Lem Evans wrote:The C3 was/is an improved cleveland by Robert Yates.
That's a small block head though, not an adaptation for a big block.
Last edited by JBR-3 on October 17th 2020, 3:30 pm; edited 1 time in total (Reason for editing : .)
JBR-3- Posts : 266
68formalGT wrote:Lem Evans wrote:The C3 was/is an improved cleveland by Robert Yates.
Like Randy said......the C460 head was a scaled up version of the C3 that Yates did for Ford.
Forget about the Cleveland.....something like a big block version of the D3 is the ticket.
Lem Evans wrote:68formalGT wrote:Lem Evans wrote:The C3 was/is an improved cleveland by Robert Yates.
The D3 is merely C3H with a larger intake port, having a 2 degree cant of the intake valve only. The C3H was made for outlaw oval track and for drag racing and is a raised intake port version of the original C3.
The D4 was the latest NASCAR head for a stock block type engine, just before Ford went to the FR9.
The SC1 is the head between the D3 and D4 which Edelbrock copied and now sells in a porters version.
THAT head up-scaled to a big block version would be really BAD ASS.
rmcomprandy wrote:Lem Evans wrote:68formalGT wrote:Lem Evans wrote:The C3 was/is an improved cleveland by Robert Yates.
Damn, if Ford would have stayed in NHRA pro stock some of that development could have happened with the big block.
Charlie
1994 is correct.
E460 was a copy of the "Olds" prostock head
Many questions
This maybe can only be answered by Kaase, but in your opinion, what will make more power. The new SR-71's or the Boss 9 heads? And also I read on another forum where a guy said that these heads will not fit on a A460 block because of the 18-bolt deal. Is this true?
Ol'Blue77- Posts : 4
Ol'Blue77 wrote:This maybe can only be answered by Kaase, but in your opinion, what will make more power. The new SR-71's or the Boss 9 heads? And also I read on another forum where a guy said that these heads will not fit on a A460 block because of the 18-bolt deal. Is this true?
The Boss9 heads are hard to beat for power. Both heads fit an A460 block just fine.
Boss9 heads usually use external rear oil returns to the pan.
Roger at Kaases’ told me that they are about even in power potential.
738drvr- Posts : 600
Turbo applications?
What do you guys think about the SR-71 if used in a forced induction application. It lacks the wow factor of Boss9, but the simplicity, space and cost savings are all leaning towards the 71s. I have 2 SCJ configured BB's and have been dragging my feet in dipping my feet into the A head arena. These seem like the new ticket, but is there any draw backs to their use in boosted applications?
Lukesportsman- Posts : 6
Call Kaase. They will tell you straight up. My only thought is that it is still a 10 bolt head. Always will be a limit at some high boost level with only 10 bolts.
738drvr wrote:Call Kaase. They will tell you straight up. My only thought is that it is still a 10 bolt head. Always will be a limit at some high boost level with only 10 bolts.
tell that to the guys running them with boost
BOSS 429- Posts : 2372
Lukesportsman wrote:What do you guys think about the SR-71 if used in a forced induction application. It lacks the wow factor of Boss9, but the simplicity, space and cost savings are all leaning towards the 71s. I have 2 SCJ configured BB's and have been dragging my feet in dipping my feet into the A head arena. These seem like the new ticket, but is there any draw backs to their use in boosted applications?
you dont need a killer head to make power with boost
Roger at Kaases’ told me that they are about even in power potential. [/quote]
that might be true for jons BOSS head
Rich, of course. The Boss 9 head is an improved factory head. Not a race head(I think that’s your point).
The SR71 is a very good head just like the Boss 9 head. It “ain’t” an A441.
738drvr wrote:Rich, of course. The Boss 9 head is an improved factory head. Not a race head(I think that’s your point).
DONT count out a TM head
Many questions #2 and a Story
Question 1:
What makes the Kaase Boss 9 Heads "not a race head"? Valves, fluid flow, head material?
Question 2:
What makes the SR-71 more of a race head?
Question 3:
I know that flat top and dome pistons need the valve reliefs for the Boss 9 heads, but do 38cc dish pistons need valve reliefs? I can't find Diamond or Mahle dish pistons that say they work with the Boss 9 heads.
Question 4:
Do the SR-71 heads have enough of a valve angle on them that the piston would need valve reliefs?
Story:
I am planning to build a 545 stroker, Hampton 8-71, Hilborn mechanical injection and stuffing this into a 65 Galaxie. About a year ago, I was dead set on the Boss 9's but now these SR-71's are out, and I am stuck between the two. I want the 38cc pistons so that I will have 8.5:1 compression and with the Hampton running 6-8 pounds, that will give around 12:1-13:1.
This is for a drag race build, in hopes to compete at Drag Week. Not necessarily to win but at least finish and average in the 9's or 10's.
Question 2:
Question 3:
Question 4:
Story:
You’re building a street engine. Either set of heads would be more than enough for what you’re doing. I would use carbs for that build. Mechanical injection is really best at the track not the street.
Man, if you're going with a big Roots type blower, I'd use the Boss heads!!
BBFTorino- Posts : 999
» Kaase K1 cam vs. K2 cam in 521 with SR71 heads?
» Sr71 heads!
» The new SR71 heads
» Kaase SR-71 Cylinder Heads
» Jon Kaase SR71 Build and Dyno results that he also tested with a Tunnel Ram
» Sr71 heads!
Page 8 of 12
