Another oil pan question
Another oil pan question  Empty Another oil pan question
Post  bruno September 26th 2018, 11:54 am
With doing an outlaw style k-member and steering rack , what is everybody using for an oil pan since there is more space. Do you still go with a dual sump/hump pan ? or are guys going with a dragster style pan
Another oil pan question  Racecr10
http://WWW.CKRME.COM
Another oil pan question  Empty Re: Another oil pan question
Post  Lem Evans September 26th 2018, 11:56 am
How much distance from the block to K/rack?
Post  bruno September 26th 2018, 12:23 pm
Lem Evans wrote:How much distance from the block to K/rack?
the only hindrance would be the ground, the oil pan would clear the kmember
Post  Lem Evans September 26th 2018, 2:07 pm
Pan depth would depend on how high the engine is in the chassis then.
Post  Lem Evans September 26th 2018, 2:59 pm
A pan needs to be at least 6.5" in the front to clear a Kaase pump.
Most "Fox" style pans are 9" in the sump, others are 8.5"...then pulled up tp ~5" in the middle to clear rack/K.
The Dragster/chassis car pans I have build are usually 7" front and 9" rear.
Post  Paul Kane September 26th 2018, 5:04 pm
bruno wrote:With doing an outlaw style k-member and steering rack , what is everybody using for an oil pan since there is more space. Do you still go with a dual sump/hump pan ? or are guys going with a dragster style pan
Generally, the greater the pan volume the better. Go as big as is reasonable and suitable.
Post  kjett September 27th 2018, 8:18 am
I've been running the Moroso 20614 chassis car pan in my mud truck. While it's not apples to oranges, it does have a 6 1/2" front that clears the Kaase pump and 8 1/2" rear with kick outs on both sides. Clears starters fine, trap door baffles and built in windage tray. Typical off the shelf pan that has served me will.
http://www.shopmoroso.com/eb/catalog/navigationPath//1::Moroso%20Performance%20Products/1100001::Oil%20Pans/11018::Ford%20429-460/%7B11991%7D::Ford%20Big%20Block.html?entryId=catalog.productgroup.1110000111018&expand=true&menuId=main.menu
kjett
kjett
Post  Dave De September 30th 2018, 8:00 pm
Lem Evans wrote:A pan needs to be at least 6.5" in the front to clear a Kaase pump.
If you can use a chassis pan buy the fab'd pan that Lem sells. It's an awesome pan that for the first time I have zero oil pressure issues at the end of the track. I don't use an accu-sump and can run the oil level (dip stick height) one quart lower than the double hump fox body pans. Trapping at nearly 150 mph has given me pressure issues in the past but not with this pan. I was concerned with header clearance but it cleared well.
Also you expect some fitment issues with a welded piece but this is a quality piece and directly mounted without any adjustment.
