1977 4V engine
1977 4V engine
Hello everyone,
I'm brand new to the forum and have a couple of questions.
1. Just bought a complete 1977 460 4V engine out of an old LTD station wagon that the local yard had with 78,000 miles. I didn't notice until I got it home that it has a factory 4bbl carb on it. I didn't think a 4V was even available in 1977. Is there anything special about this engine being it is a 4V? I was gonna just toss the heads and intake because I thought it was a 2V. Haven't checked the block number yet because it needs to be cleaned off. I would assume it's an internal balanced engine being that the flex plate wasn't weighted at all. Is that a good assumption?
2. Like to build this engine to 521. Is the 4.300 stroke too long for the older blocks without the extra length in the cylinders at the bottom?
Axshun- Posts : 20
Re: 1977 4V engine
I have never seen a 2v 460. I have seen 2v 429s though. The 4.3 stroke will work fine in that block.
cletus66- Posts : 865
Re: 1977 4V engine
Yes internal balance. You will probably have to change to external balance. The block/ internal balance change was in '79. I too have never seen a 2bbl 460 only 429 and they are rarer than the 4bbl versions by far. The '74 and later engines were pretty doggy in stock form.
gt350hr- Posts : 662
Re: 1977 4V engine
gt350hr wrote: Yes internal balance. You will probably have to change to external balance. The block/ internal balance change was in '79. I too have never seen a 2bbl 460 only 429 and they are rarer than the 4bbl versions by far. The '74 and later engines were pretty doggy in stock form.
Me too.
Re: 1977 4V engine
Is there a specific reason as to why I would have to change to external balanced? I know it seems from my research that the external balanced stoker kits are cheaper?
Appreciate the responses.
Axshun- Posts : 20
Re: 1977 4V engine
I believe the reason behind the "switch to external balance" comment was based around difficulty in internally balancing a cast stroker crank when exceeding a 4.150 stroke.
wickettoby1- Posts : 352
» Let's see your ride(s)
» 1977 Cylinder Heads
» 1977 F-150 body blueprints
» 1977 NHRA SUMMERNATS
