fuel pressure
fuel pressure
8an lines 580s 1/8 mile at 119 130 60 ft .. havent run 1/4 since i left fla 8 years ago 870 at 157. yea going thru traps at 7000 in eight mile .. pump is 12 years old.
o henry- Posts : 33
Re: fuel pressure
That's pretty fast, brother!!
If the pump has a ton of use on it, it may be showing its age. Do you have an A/F meter on board??...does it literally go lean on de-celleration?? or do the plugs look good??
I imagine that a car that fast, the pump must also overcome the inertia that is trying make the fuel go in the opposite direction.
You will certainly want to keep your eye on it, maybe even play with the pressure setting a little and do test hits.
It don't sound like you have a volume issue, just a little pressure fluctuation.
BBFTorino- Posts : 999
fuel pressure
yea its time for new pump i do not want to chance it.. no a/f meter either need to get one... carb was starting to show lean condition just recently .. my last pass i was going to check #2 plug , but i blew 13 teeth off ring gear on my 488s.. thank you so much for responding ..
o henry- Posts : 33
