Boss 545 high vacuum can for street car ?
gt350hr
mach1charlie
Building a boss 545 the question is how small . of a flat tappet cam can I get away with at 10.6 compression. Elgin 1586 s is what I'm looking at, has a lot of seat to seat timing. But at .050 shows 218 on Wallace dcr calculater.
Want to use a stock torque converter.
mach1charlie- Posts : 38
Re: Boss 545 high vacuum can for street car ?
Use a stock converter for a mid 70's Bronco with a 351M . That is about the "loosest" stock C6 converter except for the early 351CJ 10" units that are TOO loose for your application.
gt350hr- Posts : 662
The converter is easy, the cam needs to bleed of enough compression to run on CA. 91 octane
mach1charlie wrote:Building a boss 545 the question is how small . of a flat tappet cam can I get away with at 10.6 compression. Elgin 1586 s is what I'm looking at, has a lot of seat to seat timing. But at .050 shows 218 on Wallace dcr calculater.
Something custom ... about 10 more seat degrees on the intake side having only 2 more degrees at .050" with the more aggressive ramp lobe on the exhaust side.
You built an $17k+ engine and you are going to use an Elgin camshaft??
jasonf- BBF CONTRIBUTOR
Well $7,700 with kasse. Scat $1900, and a $200 truck motor. I figure 12k.
Gonna put it in an old Ranchero and use it as a driver. Eventually it will end up in my 69 Mach
I apologize in advance, but what is the sense in building a Boss headed motor, then trying to keep it tame and use mild/stock parts??
BBFTorino- Posts : 999
BBFTorino wrote:I apologize in advance, but what is the sense in building a Boss headed motor, then trying to keep it tame and use mild/stock parts??
I'm looking for a similar combo. I have an A460 block, 572 rotator with 10.1:1 comp, ported SCJ heads, and a Mafia intake. I want to be able to put pump gas in it, and drive it anywhere with EFI (looking at this one: https://www.holley.com/products/fuel_systems/fuel_injection/sniper_efi/sniper_stealth_4500/ ) OD trans and the AC pumping. I got the stuff from Lem and I have already talked to him about a custom cam. I will set up the ring gaps for unnatural aspiration. If I want to drive it to the track and hit it with a 400 shot or bolt on a centrifugal, the foundation is there.
cletus66- Posts : 865
Because the Boss 429 is the most beautiful motor ever built. I will play with this motor the rest of my life. This is just the beginning, more cam to come.
mach1charlie wrote:Well $7,700 with kasse. Scat $1900, and a $200 truck motor. I figure 12k.
Cool. I was just curious.
mach1charlie wrote:Because the Boss 429 is the most beautiful motor ever built. I will play with this motor the rest of my life. This is just the beginning, more cam to come.
rmcomprandy , who responded earlier in the thread, ground a custom cam for me several years ago. It did exactly what I asked for, and then some. The cost difference between a catalog cam and a custom cam is negligible. I suggest that you call him.
You are certainly right about that!! I put the Boss 429 in the #1 spot for beauty and eye appeal. Well, the rest of my list would be like this.....mach1charlie wrote:Because the Boss 429 is the most beautiful motor ever built. I will play with this motor the rest of my life. This is just the beginning, more cam to come.
#1...Boss 429
#2...427 FE SOHC "Cammer"
#3...Mopar 426 Hemi
#4...Boss 351 Cleveland
#5...348/409 "W" Chevy
#6...Regular big block Chevy
#7...Small block Chevy
#8...Gen III Mopar Hemi
#9...Ford Modular 4.6/5.4
#10...Mid 1950's era Jaguar inline 6 cyl. with the down draft carbs.
Just my opinion of course!!....feel free to switch it around how y'all see fit!!
1. Keep in mind your pushrod angle when trying to use a flat tappet camshaft. That was / is an issue on a Boss engine. Kaase doesn't build anything off of a flat tappet grind for that reason.
2. With your duration numbers depending on what you do for lobe sep you're most likely going to be about 16" hg.
Carbguy- Posts : 18
BBFTorino wrote:You are certainly right about that!! I put the Boss 429 in the #1 spot for beauty and eye appeal. Well, the rest of my list would be like this.....mach1charlie wrote:Because the Boss 429 is the most beautiful motor ever built. I will play with this motor the rest of my life. This is just the beginning, more cam to come.
#1...Boss 429
#3...Mopar 426 Hemi
IHMO, it's a tossup between the Cammer and the Boss, and you can't leave out the regular 427 FE either.
THATS JUST SILLY, I just did another solid lifter BOSS 429 , Solid roller,or solid lifter is the best way to go with these engines.
BOSS 429- Posts : 2372
Yeah, factory was flat tappet.
» Street vacuum pump
» CAMS ? STREETABILITY
» kaase boss 9
» is this guy high on his price NOS 429 boss crank ?? neat that he has but really that much money ?
» Tasca "Street Boss" vs "Silver Bullet" GTX
» kaase boss 9
