best intake for daily driver
best intake for daily driver Empty best intake for daily driver
Post  racinghabbit November 21st 2018, 2:01 pm
edelbrock 2795 is what I currently....
New motor 504 cid. 9.75cr, pump gas , in my 83 f100. dove heads pocket ported and bowl blended with stock size valves, cam hyd flat tappet, .563/.558  lift, duration @50  224/239, 107 intake center line. 770 holley vacuum seconday
I want really good torque 2000-4000 rpm...  NOT FOR RACING
What intake would you recommend?
Is the torker 2795 worth using?
racinghabbit
racinghabbit
best intake for daily driver Empty Re: best intake for daily driver
Post  dfree383 November 21st 2018, 2:16 pm
A Eddy Performer or Performer RPM would work well
Post  litshoot November 23rd 2018, 11:53 am
think your going to hear eddy performer, rpm(I had and like, but didn't compare except to stock), rpm airgap and weiand stealth. then a whole bunch of back and forth on which is better.
litshoot
Post  The Mad Porter November 24th 2018, 4:34 am
The original Torker intake will choke a 500" combo. Great off idle response though.
I have a new one I bought from FRPP when they were clearing inventory some years ago. Just wow...
If you want the best area under the curve use a performer. Do not port match. Add a Jomar power cone. The PC will help breathing a bit at the top by allowing a bit of cross flow and a bit of additional plenum volume.
Restrict heat through the intake by cutting a piece of stainless steel to fit in the gasket cut out for the cross over.
For cold weather use drill a 5/16" hole to allow some heat but not enough to over heat the intake and carb.
SJ
The Mad Porter
The Mad Porter
Post  Lem Evans November 24th 2018, 10:23 am
The Mad Porter wrote:The original Torker intake will choke a 500" combo. Great off idle response though.
SJ
I still have one of those FRPP original Torker if you ever need one.
Post  The Mad Porter November 24th 2018, 3:34 pm
[/quote]I still have one of those FRPP original Torker if you ever need one.[/quote]
Do you think the one I already purchased from you needs a friend?
Very Happy
SJ
The Mad Porter
The Mad Porter
