viktor to tfs mafia gains on my combo
was wondering on my combo is there any gain in your opinion on going to tfs mafia intake
i have seen results posted on tfs mafia intake but on high hp motors , here is my dyno graph made peak hp at 6300 rpm ....im wondering if this intake moves it a lot . Not sure if i would pick up anymore power but i was going through traps at 6800 range
5pointslow- Posts : 1408
Re: viktor to tfs mafia gains on my combo
forgot to add
472
eddy heads
custom solid lifter cam from rm comp
1050 davinchi carb
472
eddy heads
1050 davinchi carb
5pointslow wrote:forgot to add
472
eddy heads
1050 davinchi carb
NONE ... you may even lose power; torque for sure.
Use the money to modify the Victor.
rmcomprandy wrote:5pointslow wrote:forgot to add
472
eddy heads
1050 davinchi carb
i know this vague , but is there a lot on the table power to be gained getting this ported based on my current setup . maybe crazy to try and just use what i have just wasnt sure if intake change or modifying this one would gain much thats why i was wondering on the mafia but i know being small ci it may be to much
on other words
my car went 9.77 the way it is
i feel there is a 9.60 in the car based on being late OCT , and i highest launch was 4200 rpm my convertor flashes to 5300 rpm so if i launched at 4500 to 4600 range .
my track has 8.50 , 9.50 and 10.50 index
i can slow it up for 10.50 but wish i could pick up 2-3 tenths lol
was thinking intake and adding a vaccum pump as ways to get there but maybe im asking to much
5pointslow wrote:rmcomprandy wrote:5pointslow wrote:forgot to add
472
eddy heads
1050 davinchi carb
Maybe 10 to 20 from an out of the box Victor intake if the heads are already port matched.
What would doing the same intake swap do for a 532 TFS street head solid roller bracket engine do? Currently runs 5.50's
away- Posts : 266
» little power gains
» Viktor air gap intake
» valve lash and power gains/losses
» Mafia intake ?
» a ported viktor or could be a stock one ,4500 carb pad
» Mafia intake ?
