Header Building Advice
+14
rmk57
fordguy69
gt350hr
away
samiam
wickettoby1
18 posters
Page 2 of 2
Page 2 of 2 • 1, 2
Re: Header Building Advice
wickettoby1 wrote:If I had to guess id say that MadDog makes Crites headers for them but I don't have proof to support that besides actually going to Crites and seeing their operation.
I believe I have heard that before.
jasonf- BBF CONTRIBUTOR
wickettoby1 wrote:I had MadDog on it before, I HATE the fact that the two front tubes on each side go under the control arms, also I swiched to a rack n pinon so that complicates things further.
If you use the "back half" of the Mad Dogs , you only have to "snake " two tubes down to them.
gt350hr- Posts : 662
When i switched to the rack n pinion the Mad Dogs no longer fit, you know the old 2 things can't occupy the same space theory. And also running a manual with a blowproof bellhousing caused them not to fit very well from the beginning.
wickettoby1- Posts : 352
My current plan is the next set will be a 3/4 style header or a tri-y design. I believe it will be easier to snake 2 bigger pipes past the bellhousing and firewall vs 4 smaller.
jasonf wrote:wickettoby1 wrote:If I had to guess id say that MadDog makes Crites headers for them but I don't have proof to support that besides actually going to Crites and seeing their operation.
Don't know about these days, but back in the 90's when I bought a Crites kit for my Mustang, the headers were made by Tubular Automotive in Mass. And they told me that they built all of Crites headers.
fordguy69- Posts : 98
FPA builds their headers without the tubes going underneath the control arms. May want to check them out.
http://www.google.ca/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=2ahUKEwiVkoOetZbfAhUNB3wKHcRNCScQFjAAegQICRAB&url=http%3A%2F%2Fwww.fordpowertrain.com%2Ffpaindex%2Fheaders2.htm&usg=AOvVaw2dQqKhCfgc1dyTf52VK9TH
rmk57- Posts : 176
https://www.yellowbullet.com/forum/showthread.php?t=451097&highlight=hey+paulie9fingers#/topics/451097?page=5
This is my galaxie build from years ago. Home built headers. Front 2 tubes do run under the A-arms but are hugged up a lot tighter than the crites stuff. Back tubes run outside the frame rails because of the blow proof bell. They are about 34-35" long. If you leaf through the pictures you can see it's all tucked up tight. 2-1/4 - 4 inch collectors.
TravisRice- BBF CONTRIBUTOR
If tri Y is what you are thinking FPA makes a 390 header. Obviously it is different but the general design may aid in a mental vision of what some 460 headers may look like. I looked at the FPA headers for my 56 and they seem to think Fords need the smallest ports imaginable.
http://www.fordpowertrain.com/fpaindex/galaxie1.htm
I like the FPA designs but not the measly 1 3/4 primaries.
The last time I dealt with Crites, they were so rude and hateful on the phone, because their headers did not fit correctly, I was trying to get some info, and the owner ( I think his name is Charlie) was cursing and being a total A-hole.
BBFTorino- Posts : 999
I have a hell of a story about Crites and a set of engine mounts. They were at least 3 weeks late on delivering a set of engine mounts. When they finally showed up Crites had sent me two left side engine mounts. I talked to the owner (his name could have been Charlie) and told him I was gonna drive the 3 hours to there shop in the morning and I requested that he be there so we could chat. I'm sure you'd be surprised by the fact that he wasn't there in the morning. The best part is when they tried to exchange one of my left side mounts for a right side, the right mount box was full of left side mounts. Needless to say I vowed that day that Crites would never get another dollar of my money.
If you want great headers, check out Fab shop.
https://www.mikesfabshop.com/
Sounding more and more l like someone's looking for the best price on day old donuts. Than actually building a set of quality step headers.
This thread was started seeking advice on building a set of headers and many of the responses have been very informative. I appreciate any and all who have responded. I'm gonna order a set of flanges and a mandrel bent kit (no one or vendor has offered to sell me materials) and try my hand at header building.
Don't The Scared.......It is hard to find a shop that wants to build custom headers and they just make the price so high that you do it yourself. Kind of like being in Paint jail, they just never do it.
airford1- Posts : 192
wickettoby1 wrote:
-Does anyone who’s actually built a set of headers have any advice for a first time header builder?
I have so far built one set of headers. I did them at lest three decades ago. They are for a 351W in a 65 Mustang convertible. They are 34 inch equal length. The only way I could install them is to remove the heads. During build the heads were on and off a lot.
I had a steel shop supply eight pieces of strap with a 1.5 inch hole in the center. I bought collectors. I had a hack saw, large half round file, and a torch. I spent about a month.
They survived one engine replacement, I have just removed them and the engine. The headers still look good. However, I am now doing everything in stainless, even tho my TIG is still shaky.
I an currently doing two twin turbo headers. One is for a 351/427W for the convertible. The other is for a 460/604 for a 55 Ford wagon. They both have Trick Flow heads. The 351 has typical rectangular ports. For that I bought a set of stainless headers for the flanges and stubs, and pipe - $100. I also bought cast stainless T3 to V band adapters, short 90 degree bends, U bends, and donuts.
The 460 TF heads have a raised floor. I had a laser shop cut eight stainless flanges, and internal dies to form the tubes. Note: mild steel will form cold, stainless will not.
All the connections are V Band.
I have the old 351W set up as a jig.
Main requirement is patience.
RayDav- Posts : 27
How about some recommendations for material suppliers? Flanges, collectors, mandrel bends, ect...
Summit Racing sell weld up kit for less than $200 without flanges call Keith he can probably build you a set of flanges
This guy knows more about headers than anyone and should have everything you need, http://www.headersbyed.com/
Mike R- Posts : 1381
I've been on that website many times looking around.
Page 2 of 2 • 1, 2
» building serious bbf need help and advice
» 552 header advice
» Building a ´71 SCJ now - take two
» building a sc 460
» Building A Mean 460...?
» 552 header advice
» building a sc 460
Page 2 of 2
