Toploader Tricks
747JetMech
Toploader Tricks Empty Toploader Tricks
Post  747JetMech December 13th 2018, 2:02 pm
My son decided he wants to run a toploader behind his Cleveland. So I think there is a roller bearing available for the pilot bushing. Numbers?
I have a toploader out of a 1970 351 C Torino. I ran this transmission years ago but it was a bear to speed shift. Does anyone have any tricks to use on this to get it to shift easier? I heard of filing off every other tooth but will that make it impossible to drive on the street? I will need to look up the ratio for this transmission but if I remember, it is a wide ratio unit. The Cleveland is a 600HP unit installed in a 1970 Maverick.. Any links to read to school myself would be appreciated..
Thanks for your help fellas..
Last edited by 747JetMech on December 16th 2018, 3:17 pm; edited 1 time in total (Reason for editing : Not syncro)
747JetMech
747JetMech
Toploader Tricks Empty Re: Toploader Tricks
Post  stanger68 December 13th 2018, 2:53 pm
Very likely the shifting problems were not the transmission. Need a Hurst shifter and replace the clutch arm that bolts to the block with a custom built clutch arm that does not flex. With a heavy duty pressure plate the stock clutch linkage flexes and will cause you to miss gears. We took the one off my brothers car to a machine shop and had them copy it but added reinforcements and built it out of 1/2” aluminum bar. No more missed shifts after that.
Toploader Tricks Empty Thanks
Post  747JetMech December 14th 2018, 12:07 pm
Picked up a Super Shifter for it... I will work over the clutch rod when we get that far. Heim joint instead of the rod with a hole and cotter pin. We have regular motor mounts so I am sure there is some flex in there. Maybe I should put solid mounts in the car and eliminate that.
Its going to be a street strip deal..
747JetMech
747JetMech
Post  stanger68 December 14th 2018, 6:41 pm
Dan Williams top loader in North Carolina used to be the go to guy for anything to do with a top loader. Couldn’t find a website for him they must’ve went out of business. Good luck.
The equalizer bar I think is the proper name for the clutch arm we had fabricated.
Post  bosshoss December 15th 2018, 6:36 am
david Kee toploaders sells any parts you might need.
dkp
bosshoss
bosshoss
Post  rbro460 December 15th 2018, 2:34 pm
2x on Kee
rbro460
rbro460
Post  747JetMech December 16th 2018, 3:19 pm
I will give him a call next week.. I have been watching the South East Gasser videos and its getting a fire started under my ass to get this done. They seem like a bunch of good guys and run sticks in their cars..
747JetMech
747JetMech
Post  gt350hr December 17th 2018, 5:12 pm
Use the needle bearing pilot bearing for a '90-2005 Mustang 5.0 . Epay has them for cheap. All made by the same place regardless of name on the package.
gt350hr
Post  maverick532 December 19th 2018, 10:27 pm
For what its worth ditch the mechanical clutch linkage and go hydraulic I had very good success using Mcleod clutches hydraulic system with my Maverick back when it had a Cleveland with a top loader in it , was a lot of fun too banging gears .
maverick532
