Looking for info on how to upgrade my c6 for mud racing (need some Tips & tricks)
bigunitmudracing
Going to be a well build 460 in front of this!!
a friend on here was talking about some penny trick and rollerizing and something with a band, looking for exactly how to do these and more!! thanks!!
bigunitmudracing- Posts : 159
Re: Looking for info on how to upgrade my c6 for mud racing (need some Tips & tricks)
There is a long post on here that GearHead559. put up. did his like Frank M. dose them.
edit: put the right name to it.
res0rli9- BBF CONTRIBUTOR
I would do a complete rebuild with good parts for starters.
Rollerizing is a good option for the $, even better if you have machining skills and access to a lathe.
Upgrade the servo or apply lever to apply more band pressure. With this upgrade you might want a new band with welded tabs.
You can do a shift kit on your valve body or get a new one.
I mud raced with a stock c6 for several years before it started slipping on 2-3 shifts. The guys below helped me with parts and tech on my rebuild.
If your looking for parts with great customers support give Jay @ Broader Performance a call http://www.broaderperformance.com/ .
For technical help here, Frank Merkl would be the house expert, guru, go to guy, etc..
Hope I was some help
mike
mike
f250mike- Posts : 628
Here's a good read. Sorry I had the wrong posters name.
http://www.460ford.com/forum/showthread.php?t=113120
Could you work with me, going to start building a C-6 next week... I work at a parts store and we are a distrubtor for TCI, B&M
Thanks!
Thanks!
All the information you need is on the above link , read it! instead of typing
Frank Merkl- Posts : 1524
I got one question, I put a manual tci valve body in my last c6 and the shift between 2nd and 3rd was sorta delayed... what do u think of that???
thanks
thanks
bigunitmudracing wrote:I got one question, I put a manual tci valve body in my last c6 and the shift between 2nd and 3rd was sorta delayed... what do u think of that???
thanks
I don't have a fix for the TCI (Trash Can Industries) manual vb 2-3 flair . but tightening the band to 120 in/lbs and backing the adjuster screw off only 3/4-1 turn seems to help. instead of the normal 1 1/2 turns
the rollerization info doesn't come up when i click on it??
can i use some parts from a E40D for rollerizing?
bigunitmudracing wrote:the rollerization info doesn't come up when i click on it??
Just worked for me .....Try copying and past the link in you address bar.
where is the info on upgrading a stock valve body to make it like a manual one..????
there isn't because (instructions)I sell them but am sold out for this year
frank you got mail.. and Y only exhaust?
I think Frank mentioned the other night the pics were lost somehow.
Post #15 in the thread however, has 'em reposted. (Good job Mike).
It's basically replacing the thrust bearings with needle rollers. Cool deal.
If I keep my C6, I'm going to do it too.
23Alt- Posts : 33
this doens't help me any... how much are they??? if you had one
$450 + shipping
Broader performance
I purchased 1 of there 500 hp rebuild kits , rebuilt it myself works great . the tech support was very helpfull and the kits and all was verry affordable .
1fatcat- Posts : 44
» Tips and Tricks
» Need some tips or tricks for driling out a timing cover bolt on a SBF
» I'm looking for tire info for drag racing my truck.
» Toploader Tricks
» Tricks with stock cranks?
» Toploader Tricks
