Scorpion 1024 vs 1056?
+8
torino501
Wayne Pearce
gt350hr
bigford632
samiam
racinghabbit
12 posters
Scorpion 1024 vs 1056? Empty Scorpion 1024 vs 1056?
Post  racinghabbit January 5th 2019, 8:00 pm
Scorpion 1024 vs 1056 ? What’s the difference there catalog doesn’t say
racinghabbit
racinghabbit
Scorpion 1024 vs 1056? Empty Re: Scorpion 1024 vs 1056?
Post  samiam January 5th 2019, 11:09 pm
I've read the 1056 has a larger body and requires less shimming,, but same as you, I couldnt get any real info
samiam
samiam
Post  racinghabbit January 6th 2019, 12:02 am
I’m buying pushrods anyway so do I need to worry about shims?
racinghabbit
racinghabbit
Post  69F100 January 6th 2019, 9:59 am
When you order the push rods call Smith Brothers they will build you any length you need . I will only buy my push rods from them now on.
Post  bigford632 January 6th 2019, 5:52 pm
http://351c.net/board/index.php?/topic/3732-confused-about-scorpion-pedestal-mount-roller-rockers/
bigford632
Post  gt350hr January 7th 2019, 3:07 pm
There are some really inexperienced people over on that forum.
gt350hr
Post  racinghabbit January 7th 2019, 6:07 pm
I made a last minute decision change.. I ordered the crane stud kit 52655-16 and a set of comp 17045-16 rockers.
I have done pushrod length plenty of times and it will just be better for me.
racinghabbit
racinghabbit
Post  rmcomprandy January 7th 2019, 8:38 pm
racinghabbit wrote:I made a last minute decision change.. I ordered the crane stud kit 52655-16 and a set of comp 17045-16 rockers.
Good luck ... it is less sturdy than the bolt down rocker system but, it will be more adjustable.
Post  racinghabbit January 8th 2019, 12:59 am
Anything has to be better than the failed stock rockers, that sent tons of metal threw the lower end and taking out my bearings
racinghabbit
racinghabbit
Post  racinghabbit January 9th 2019, 11:08 am
Scorpion 1024 vs 1056? 184d6810
[url=https://servimg.com/view/18722508/15]Scorpion 1024 vs 1056? Fd5cdf10[/url
racinghabbit
racinghabbit
Post  Wayne Pearce January 9th 2019, 11:58 am
I had these on my daughters 429 Fox body. I was skeptical of them, but she put a rod through the side of the block before any of the rocker studs failed.
Wayne (SAWDOFF) Pearce
Wayne Pearce
Post  racinghabbit January 15th 2019, 9:35 am
There noisy! I used a very similar setup on a small block a few years back and had the same issue.. seems like the pushrod and that plastic guide make the noise. But functions great
racinghabbit
racinghabbit
Post  racinghabbit January 15th 2019, 9:36 am
Scorpion 1024 vs 1056? 202df310
racinghabbit
racinghabbit
Post  torino501 January 15th 2019, 10:57 am
racinghabbit wrote:Anything has to be better than the failed stock rockers, that sent tons of metal threw the lower end and taking out my bearings
TOto strong of a spring for the factory stamped rockers.
torino501
Post  69F100 January 16th 2019, 5:17 am
I ran this same set up on my old 351c only problem i had was keeping the studs tight. Even with the red loctite they would still work loose.
Post  Mark Miller January 17th 2019, 12:18 am
69F100 wrote:I ran this same set up on my old 351c only problem i had was keeping the studs tight. Even with the red loctite they would still work loose.
Same here had them on my 460 with D3VE heads a long time ago and also had the studs coming loose!!! Smile
Post  racinghabbit January 17th 2019, 11:17 am
how did you notice there was an issue?
racinghabbit
racinghabbit
Post  69F100 January 17th 2019, 12:41 pm
Lifters would get noisey or it would start skipping and bend a push rod
I always kept a extra push rod in the glove box with allen wrench and a 5/8 end wrench fix it on the side of the road
Post  Paul Kane January 17th 2019, 12:47 pm
racinghabbit wrote:Scorpion 1024 vs 1056 ? What’s the difference there catalog doesn’t say...I made a last minute decision change...I ordered the crane stud kit 52655-16 and a set of comp 17045-16 rockers...it will just be better for me. Anything has to be better than the failed stock rockers, that sent tons of metal through the lower end and taking out my bearings
I don’t know the details of your current engine build, just want to emphasize that when properly set up and optimized the OEM pedestal rocker arm valve train has numerous attributes over the aftermarket rocker arms and stud system you are considering instead.  I’ve known the OEM stamped steel rocker D3 valve train to be used successfully (and long term) in engines wth cams over 0.600” lift. And I don’t think I’d do that with the Crane stud conversion kit.  Again, it really depends on the details and needs of the build.
Post  BOSS 429 January 17th 2019, 8:01 pm
what did were you guys tq the studs to?
Post  Mark Miller January 17th 2019, 11:23 pm
I don't remember this was probably in the early 90's and if the Crane Conversion gave a torque rating that's probably what I torqued them too!! Smile
Post  Mark O'Neal January 18th 2019, 12:24 am
Medium low tight with a 1/2" drive.
Mark O'Neal
Post  racinghabbit January 18th 2019, 10:54 am
i put mine at 25ftlb with red lock tight.
racinghabbit
racinghabbit
