Measuring Cam lift at the retainer
Measuring Cam lift at the retainer Empty Measuring Cam lift at the retainer
Post  HorsinAround January 27th 2019, 6:51 pm
I apologize for the newbie question..... I am have one of my new heads on the bench and am setting up to check the geometry on my rockers to see if I need to adjust the pedestal height. Here is the question; my cam card says Intake lobe lift is .468 and valve lift is .809. So am I correcting in setting the dial indicator up on the retainer at .809 and roll the rocker until the dial indicates 0?
Measuring Cam lift at the retainer Head10
http://www.frontpagefab.com
Measuring Cam lift at the retainer Empty Re: Measuring Cam lift at the retainer
Post  rmcomprandy January 27th 2019, 8:03 pm
The valve lift listed is merely "Theoretical" valve lift as is only true IF the rocker arm provides the exact ratio as it is listed to do AND the pushrod is exactly straight and parallel to the lifter.
THAT almost never happens.
LOBE lift can be measured at the lifter or the pushrod if it is exactly parallel to the lifter ... which it is not, in the case of a big block Ford engine.
Post  HorsinAround January 30th 2019, 12:34 pm
Thanks for the information. I won't touch the pedestals until I get the block back from the machine shop. But is my set up right to get a general idea of the roller contact pattern on the valve tip?
Post  rmcomprandy January 30th 2019, 1:47 pm
HorsinAround wrote:Thanks for the information. I won't touch the pedestals until I get the block back from the machine shop. But is my set up right to get a general idea of the roller contact pattern on the valve tip?
Contact pattern is not a good way to determine correct geometry on a big block Ford engine ... but, it should get you close.
