Gasket issue
racinghabbit
Gasket issue
I have not been having any luck with fel-pro intake gaskets... what are others running for intake gaskets ... I use a edelbrock victor intake Dominator flange. max effort DOVE heads.
Also does anyone make a 1 piece oil pan gasket that will work on the early 460? I tried a felpro one for like a efi block and there not the same.
racinghabbit- Posts : 575
Re: Gasket issue
racinghabbit wrote:I have not been having any luck with fel-pro intake gaskets... what are others running for intake gaskets ... I use a edelbrock victor intake Dominator flange. max effort DOVE heads.
Fel-Pro black "Print-O-Seal" race intake gaskets are made to be replaced.
I use the Mr. Gasket "plain" gaskets.
Re: Gasket issue
Victor Reinz 95074SG works for me . Those are the CJ port size . I had no luck either with those Printoseals .. Some on here also have had a good run with SCE.
I used the Ford Racing one piece pan gasket but made a fixture to clamp the corner inserts to drill them
Gregaust- Posts : 626
Re: Gasket issue
Been using the Cometic intake gaskets.
And I've never had an issue with a one piece oil pan gasket. I just helicoil the corner bolts so they're smaller like the rest of the oil pan bolts...
jbozzelle- Posts : 3705
Re: Gasket issue
jbozzelle wrote:Been using the Cometic intake gaskets.
Same here..........
Re: Gasket issue
if you have to down size the 4 end holes in the block your using the wrong gasket, order the early one.
As far as intake gasket go,I love the print o seal ( 1230s and 1231s), wont use anything else. going to use 2 pair today.
BOSS 429- Posts : 2372
» Head Gasket Issue
» rod issue and how can in fix it?
» Wierd smoke at start up
» anyone a animal vet? holstien bull question
» 429 CID in a FOX body - 1050CFM jetting.
