Head Gasket Issue
maverick532
Head Gasket Issue
Have Cometic head gaskets , rivets hitting deck surface , instruction sheet states all rivets must clear deck and head surface . A460 block , P51 heads . Lem , Charlie , Randy , Rich , Jon , those of you using them advise please .
maverick532- Posts : 181
Re: Head Gasket Issue
was wondering if thats what was being done . the thought had run thru my mind . thx lem .
I clearanced the block with a stone in a dremel tool....... easy deal
Like Lem said, drill the rivets out. If you still want to hold the layers together, you can use plastic tie wraps in those same holes, and the plastic is compressable,
Charlie
Charlie
c.evans- BBF VENDOR SPONSOR
I have the A460 block, P51s, and cometic gaskets, and I didn't have to do any of that---it looked to me the rivets cleared everything.........wonder if I missed something
They cleared my IUD block too, I mean IDT block
Thanks guys . Jon I had wonderd if you had done that . Paul I noticed they contact the block at the upper bolt holes for the 18 head bolt deal and at the outer edge of the deck .
Maverick532,
Have you got A-460 heads and 10 bolt gaskets? It's not a problem with the P-51 heads that Paul has.
Charlie
Charlie
Charlie I have the same as Paul , A460 block P51 heads
Lem Evans wrote:Given where the rivets are it may not matter any way.
In that case it aint a big deal with the P51.
mine too..........IDT-572 wrote:They cleared my IUD block too, I mean IDT block
cool40 wrote:mine too..........IDT-572 wrote:They cleared my IUD block too, I mean IDT block
Your IUD or IOU
do IOU a IUD?Lem Evans wrote:cool40 wrote:mine too..........IDT-572 wrote:They cleared my IUD block too, I mean IDT block
Your IUD or IOU:)
