Muffler Choice For Street Car
+7
Carl
68galaxie
fordguy69
octanehuffer
wickettoby1
11 posters
Muffler Choice For Street Car Empty Muffler Choice For Street Car
Post  wickettoby1 January 30th 2019, 2:11 pm
I'm not trying to start a fight here but what mufflers are you guys and gals using on your healthy street cars here in 2019? There are so many options its hard to pick especially without hearing them first hand.
wickettoby1
Muffler Choice For Street Car Empty Re: Muffler Choice For Street Car
Post  octanehuffer January 30th 2019, 2:50 pm
Borla 4" XR1 21" long
octanehuffer
octanehuffer
Post  rmcomprandy January 30th 2019, 5:52 pm
wickettoby1 wrote:I'm not trying to start a fight here but what mufflers are you guys and gals using on your healthy street cars here in 2019? There are so many options its hard to pick especially without hearing them first hand.
What diameter pipe and how much room do you have for case volume...?
Post  wickettoby1 January 30th 2019, 5:57 pm
Plan is 3' diameter pipe and it's a '64 Galaxie so rectangular or oval would give more ground clearance.
wickettoby1
Post  fordguy69 January 30th 2019, 6:53 pm
I have Hooker Aero Chambers on my 69 Mustang with a 466. 3" with x pipe, all the way to the back. I had Hooker Maxflo's on it but they were too loud for my wife! The Aero's are a little quieter, but not much.
I just put Magnaflows 13219 on my 87 Mustang with a 521. 3" with x pipe, exiting out the sides after the rear tire. They are much quieter than either of the Hooker's and have a very good sound but they aren't a straight through like the Hookers, so they may not flow quite as well?
The Magnaflows are a significantly smaller case so they also packaged a little easier.
fordguy69
Post  68galaxie January 30th 2019, 8:52 pm
3 1/2" 3 chamber flowmasters on mine.
Not exactly stealth.
68galaxie
68galaxie
Post  rmcomprandy January 31st 2019, 11:45 am
wickettoby1 wrote:Plan is 3' diameter pipe and it's a '64 Galaxie so rectangular or oval would give more ground clearance.
I have tested many 3" mufflers for sound level and power on the dyno so this is merely at wide open throttle.
The "Extreme Mufflers" from Extreme Technologies were far and away the best. for BOTH sound control and power. Some we tested were as powerful and others had as good sound control but, not Both ... except these.
The 14" semi-oval case #1014-3030 are great. At a later date we compared their 18" case #1018-3030 and they are even quieter yet the power level was the same.
Not a very well known company and I have no idea why except that they don't advertise nationally, much.
Post  68galaxie January 31st 2019, 12:20 pm
Thank you Randy!
I certainly will look at what Extreme Technologies has available.
I like hearing the engine, but also being able to hear a passenger talking (not yelling).
68galaxie
68galaxie
Post  wickettoby1 January 31st 2019, 1:17 pm
I also have never heard of extreme technologies. Randy, do you have any sound clips or can you compare it to another brand just for a reference?
wickettoby1
Post  Carl January 31st 2019, 4:05 pm
Another option is a cheap/quiet muffler with electric cut-outs in front of them. Open header power at the flick of a switch.
Carl
Post  wickettoby1 January 31st 2019, 4:07 pm
Carl
I've thought about that too
wickettoby1
Post  HorsinAround January 31st 2019, 8:50 pm
Check out the Cherry Bomb Vortex.
https://cherrybomb.com/project/vortex/
http://www.frontpagefab.com
Post  jasonf February 1st 2019, 2:24 am
Looking at all the mufflers mentioned I am curious as to at what point do you need a 3" or 3 1/2" or 4"?
Post  TravisRice February 1st 2019, 7:45 pm
https://www.jegs.com/i/Dynomax/289/17267/10002/-1?CAWELAID=1710592300&CAGPSPN=pla&CAAGID=61640385282&CATCI=aud-324171083249:pla-570187338865&CATARGETID=230006180041398612&CADevice=m&jegspromo=thirdparty&gclid=EAIaIQobChMI_pGXvtmb4AIVBWSGCh23cw95EAQYAiABEgKnHPD_BwE
I have these USA MADE 6" round Dynomax Stainless mufflers on my pump gas 532 truck engine. They are straight thru and I have 3" with an x pipe and turn downs on my lowered 67 F250 with a 5 spd. They have a real good sound at idle and actually with the XPipe they quiet down at little at cruise speeds.
Travis
Post  DaveMcLain February 2nd 2019, 9:50 am
From my experience testing this sort of stuff any muffler that you can't see through doesn't perform very well and it can often be louder than a straight through absorption type of muffler. Also it seems that the closer to the end of the pipe/farther away from the engine the more effective the muffler is when it comes to reducing noise without hurting power.
Any of those mufflers like the Magnaflow, Dynomax etc that are straight through seem to work about the same. I have a set of 3 inch Magnaflows that I've used for many years on my dyno and they work well. I also have a set of those Schoenfeld straight through ones from Speedway Motors that I sometimes use on 3.5 inch exhaust. They work surprisingly well and they are less than $20.
DaveMcLain
Muffler Choice For Street Car Empty Hush thrush
Post  capncruncher1965 February 9th 2019, 12:05 am
3.5 exhaust X pipe hush thrush mufflers with turn downs. Quiet until you hit it lol
capncruncher1965
capncruncher1965
