Digital Dash
Digital Dash Empty Digital Dash
Post  75truck February 14th 2019, 1:22 am
Been a while since I have posted anything.
Finally got my 1975 F250 running after a downtime of 6 years.
Rebuilt 429 to almost Cobra Jet specs.
Put a ZF-5 trans in and needed a solution for the speedo that won't adapt from the orig truck to the ZF.
So here is my solution right from Ebay.
A digital dash gauge set. With a GPS Speedo.
75truck
Digital Dash Empty Photos are not showing up?
Post  75truck February 14th 2019, 1:27 am
Trying to post / add jpeg photos?
Help?
Bob
Tucson
75truck
Digital Dash Empty Re: Digital Dash
Post  TravisRice February 14th 2019, 7:10 am
You must have a later model ZF. I have a 92 trans behind mine in a 67 truck that has a speedo gear in the trans.
Someone makes a conversion to do this without going to a digital dash. Unfortunately I cant remember what called.
Post  75truck February 14th 2019, 12:21 pm
Trying to add a jpeg and get this message
Uploaded file is not valid: exceeded attachment maxsize (0 kB).
75truck
Post  jbozzelle March 3rd 2019, 1:53 pm
Read this post. Should help you get pics uploaded. What GPS Speedo did you go with?
https://www.429-460.com/t26524-pic-uploading-made-easy
Post  75truck March 3rd 2019, 11:43 pm
Digital Dash 72_x_210
Finally got photos to load pic shows panel prior to installing. Got aluminium panel from Boese Engeneering on Ebay.
Digital Dash X72_110
Shot shows backside with the wiring and small assesory fuse panel got at Autozone.
Pretty easy to install. Just takes time. Used a 12v test lite and a digital volt meter
to trace and check the wires that were disconnected from the original panel.
Digital Dash Img_2412
Installed! Easy no major hurdles. The angle of the panel is just a little awkward but still looks good. Its a little hard to see the speed
when driving because of the installed angle.  Got the GPS Speedo kit on Ebay with all guages for around $230.00.
As soon as I hooked up the speedo and went for a drive the speedo was almost right on.  So far I'm not quite sure how to calibrate.
Maybe some could post a procedure for this.
Digital Dash Img_2413
Sure looks good at nite!
Bob
Tucson
75truck
Digital Dash Empty Hookup the gas switch and fuel guage.
Post  75truck March 3rd 2019, 11:53 pm
Next step is to hook up the fuel sender wires.
At this point I'm almost over my head. Not quite sure how to wire for the fuel gauge. The kit did come with a complete sender for the tank also.
I had to buy a new rear tank and sender prior to getting the kit.  Let the truck sit for about 6 years befor getting it running again and the tank rusted out.
The gauge kit came with all the gauges and senders except I don't think it came with a magnetic sensor for the Tach.
I think I need to purchase it separately.
75truck
Post  jbozzelle March 4th 2019, 1:21 pm
Sweet looking truck. The gauges look nice too. The fuel sender should be pretty straightforward as long as the gauge is set up for the same resistance as the factory gauge. Or you may have to use the sender that came with the gauge
Post  Mustang-junky March 6th 2019, 10:15 pm
I got this one for my 1979 f-150. Price was right, comes with new senders for the oil pressure, water temp, and speedo adapter. Is available in four colors.
https://www.ebay.com/itm/For-Ford-Courier-73-79-Intellitronix-Direct-Fit-LED-Digital-Gauge-Panel-Blue/302854510375?fits=Model%3AF-150&epid=9025308983&hash=item4683891727:g:4JAAAOSw8WdbfX~Y&frcectupt=true
Digital Dash S-l1600
I haven't installed it yet, waiting for the weather to warm up.
Jess
Mustang-junky
Mustang-junky
