Torque converter studs/bolts
Torque converter studs/bolts Empty Torque converter studs/bolts
Post  STR-LGL-70 February 20th 2019, 7:46 pm
So I'm ready to put my engine in chassis and have a new CSR flexplate and their ARP 7/16" converter bolts but just realized that my converter has studs, not threaded bosses for bolts, anyone else have this? Also, they are 1/2" diameter and will not fit flexplate with out drilling out the holes which I really don't want to do. Does this sound like something a competent converter shop would/could fix?
Thanks,
Sheldon G.
STR-LGL-70
STR-LGL-70
Torque converter studs/bolts Empty Re: Torque converter studs/bolts
Post  Copperhead February 21st 2019, 8:44 am
Don't over-think it.
If you have a Drill-Press,.....you can do this at home.
Copperhead
Copperhead
Post  STR-LGL-70 February 25th 2019, 8:42 am
Thanks for the info, I went ahead and had FTI build me a converter, so I won't have to drill my flexplate. Found out my old one was only 3200-3400 according to JW. That would partially explain the soft leaves from before with my old combo.
Sheldon G
STR-LGL-70
STR-LGL-70
