Main studs or Bolts
LivermoreDave
powerstrokeace
Main studs or Bolts Empty Main studs or Bolts
Post  powerstrokeace October 2nd 2013, 10:59 pm
i didnt really get a clear answer but this is a 2 bolt block and i'm wondering if main studs are any good or if i should stick with bolts
Ace
powerstrokeace
powerstrokeace
Main studs or Bolts Empty Re: Main studs or Bolts
Post  IDT-572 October 2nd 2013, 11:09 pm
I have used both and not seen a problem with either.
I use grade 12 Socket head cap screws on all the blocks I convert to aftermarket 4 bolt caps.
Post  cool40 October 3rd 2013, 9:42 am
Bolts work.
Post  LivermoreDave October 3rd 2013, 10:20 am
If the studs don't interfere with assembly I like using them, however in applications that limit cylinder head removal, bolts are my preference. In a few lightweight projects I have participated in I documented no difference as to the clamping force or the ability of studs to clamp the main cap versus bolts. I am a believer that the main webbing and/or material must be present to appreciate additional clamping.
Dave.
LivermoreDave
Main studs or Bolts Empty Do not use
Post  460Dave October 4th 2013, 9:04 am
Pioneer studs. They are slimmed down in the middle and allow more cap walk than others. I used them and was very sorry.
460Dave
Post  torino501 October 5th 2013, 10:16 am
im assuming main studs...?it was either this site or over at the other one.but there was a debate over cap walk.looks as if ford had two different main bolts.one had a solid shoulder from the bottom of the head all the way down to the threads.it was thought to help prevent cap walk over the other main bolt that ford offered.its shoulder only came down about .500 from the bottom of the head and necked down from there to the threads.basicly there was a lot of room in between the main bolts and the main cap bolt holes.the arp studs are rather small as well between the bolt and the main cap bolt holes.its like it needs to be shimmed to take up some room in there.
torino501
Post  IDT-572 October 5th 2013, 12:55 pm
I have never seen factory bolts with a shoulder all the way down.
Post  racnrick October 5th 2013, 8:20 pm
IDT-572 wrote:I have used both and not seen a problem with either.
A little off topic, and I think it has been discussed before, but what is the thought on using the grade 12 socket head screws for head bolts?
racnrick
Post  cool40 October 5th 2013, 9:17 pm
i've used them when i mill the heads off for port plates.never had any trouble.
Post  Lem Evans October 5th 2013, 10:33 pm
That's what we used in the mid 1980s for the original TFS heads. There were no stud kits.
