ARP main bolts/studs for A460 block ?
I just talked with ARP and they said they don't have a part number for this block but can hook me up with individual bolts. What has anyone else used and who stocks them ?
paulie9fingers- Posts : 134
Re: ARP main bolts/studs for A460 block ?
Unless you are runing a serious power adder just run the bolts that came with the block .
If a guy wants to do studs just get the ones for a 2 bolt block...about $56 as best I can remember.
x2 what lem said, totaly unnecessary to run studs.
Thank you guys, I will be spraying nitrous on this engine occasionally, no more than 300 hp (I think the engine should make around 950 HP without nitrous without a problem). I don't need to spend money for no reason, I'll use the ones that came in the block if yall think that'll be fine.
» Main studs in a460 block ?
» Need New Outer Main Bolts for A460 Block
» torque specs for svo block splayed main cap bolts
» Main studs or Bolts
» main bolts or studs or not......
