Main studs in a460 block ?
kim
rocketpony
Main studs in a460 block ? Empty Main studs in a460 block ?
Post  rocketpony April 1st 2015, 3:45 pm
I bought a 600ci with c460 heads and a A460 block. It has main bolts in it.
So I'm assuming there's main studs available for the Ford racing A460 block right? And wouldn't it b a good idea to run studs, or are the bolts well enough
rocketpony
Main studs in a460 block ? Empty Re: Main studs in a460 block ?
Post  kim April 1st 2015, 3:59 pm
bolt versus stud, when used correctly, no change in clamping capability. The bolts for the block are fine. Studs won't hold any more load.... they are just harder for the layperson to F up using.
kim
Post  schmitty April 1st 2015, 6:16 pm
rocketpony wrote:I bought a 600ci with c460 heads and a A460 block. It has main bolts in it.
Got over 1000 lb/ft of tq in mine, and the bolts are doing just fine. Cool
Post  dfree383 April 1st 2015, 7:29 pm
Bolts on all my a460 blocks too.
Post  rocketpony April 1st 2015, 9:08 pm
Guess il stick with the bolts then
rocketpony
Post  hienergy557 April 1st 2015, 9:14 pm
I have studs on the inners and bolts on the outer. I did have it line honed with the studs.
hienergy557
hienergy557
Post  Lem Evans April 1st 2015, 10:04 pm
If you just gotta have studs.....get a the same kit for a stock block....it'll do the inner vertical units.
I just run the A460 bolts.
Post  rocketpony April 2nd 2015, 7:39 am
I noticed also that there's no washers used with the bolts, is this correct? Seem odd to me
rocketpony
Post  Lem Evans April 2nd 2015, 10:12 am
No washers is correct.
Post  rocketpony April 2nd 2015, 10:41 am
Ok, thanks a lot for the help, it's greatly appreciated
rocketpony
