A460 block with cracked main cap
derek528
I'm looking at buying a used a460 block, but the current owner told me the front main cap is cracked. Anyone here ever broken a cap on one? Should I consider buying this if the price is right? My brother runs a machine shop so replacing the caps and and boring the mains can be done for just the price of the caps. Are the mains available separate from the block?
Thanks Derek
Thanks Derek
derek528- Posts : 115
Re: A460 block with cracked main cap
I never heard of cracking caps as a problem, I'd be worried about other stress problems, what was the block used for??
Make sure it's the cap and not the block that is cracked at #1. There has to be a blown A460 sitting somewhere with a good #1 cap.
dfree383 wrote:I never heard of cracking caps as a problem, I'd be worried about other stress problems, what was the block used for??
Yeah I'm worried about that also. He didn't say what the block was used for. If I could get it cheap enough I think it might be worth my time. It seems to me it could be two things, either it could have possibly been a defective cap, or the block has underwent lots of abuse, or a combination of the two.
........ .......rmcomprandy wrote:OR ... someone dropped the block on the front main.
odder things have happened.
I'm pretty sure I have an extra front main from an A-460 block. Just got to find it in the garage.
Uncle Charlie
Uncle Charlie
c.evans- BBF VENDOR SPONSOR
c.evans wrote:I'm pretty sure I have an extra front main from an A-460 block. Just got to find it in the garage.
Uncle Charlie
Thanks Charlie, I'll get with you if the deal goes through.
I 've seen that done. It cracked the block right next to the front main stud.
maverick- BBF CONTRIBUTOR
It turns out that the block is cracked in the main saddle. I could've swore that he said the cap was cracked, but I may have just misunderstood him.
Thats one to pass on.......
derek528 wrote:It turns out that the block is cracked in the main saddle. I could've swore that he said the cap was cracked, but I may have just misunderstood him.
buy the caps
138- Posts : 1593
Usually the result of a spun main that got really hot, the main almost always cracks perpendicular to the saddle right across (and through) the main oil feed, or it cracks in-line with the saddle from the main oil feed to the cam oil feed....or it cracks in both places.derek528 wrote:It turns out that the block is cracked in the main saddle.
Technically, such a main web crack is repairable by knowledgeable and experienced expert, but in an A460 block that may see gobs of power you are better off starting with a clean slate.
Paul
Paul Kane wrote:Derek, what is the asking price for this block?
He wanted 1500 for it and a set of used oliver 6.8 2.200 rods. When he told me that the block was cracked I lost interest and didn't negotiate any further. It seems like he doesn't want to sell the block alone.
Was this deal some kind of "find" on the internet? Was it's number 1 main webbing cracked all the way up to the camshaft?
Charlie
Charlie
c.evans wrote:Was this deal some kind of "find" on the internet? Was it's number 1 main webbing cracked all the way up to the camshaft?
Charlie
He just told me that it has a hairline crack in the main saddle connecting to one of the bolt holes. I found the block on racing junk. It is about 1.5 hours from me, so I have not seen it in person.
I'd run away from it,,,,,if you are planning on making any kind of serious horsepower.
Charlie
Charlie
c.evans wrote:I'd run away from it,,,,,if you are planning on making any kind of serious horsepower.
Charlie
Yeah I decided against using it as soon as I found out the block was cracked. I've been looking for a used a460 block for awhile now, I guess I'll just keep looking.
this may not sound like i mean for it to so dont take me wrong,after having a few ass burnings you'll figure out that a new block would be a good investment.all too often the good deals are not so good by the time you fix a used part.if you stick with the folks on here you'll be ok but know what your payen for and what you want.derek528 wrote:c.evans wrote:I'd run away from it,,,,,if you are planning on making any kind of serious horsepower.
Charlie
cool40 wrote:this may not sound like i mean for it to so dont take me wrong,after having a few ass burnings you'll figure out that a new block would be a good investment.all too often the good deals are not so good by the time you fix a used part.if you stick with the folks on here you'll be ok but know what your payen for and what you want.derek528 wrote:c.evans wrote:I'd run away from it,,,,,if you are planning on making any kind of serious horsepower.
Charlie
I agree. I will probably end up buying a new block, but I'm still keeping me eyes open for a deal too good to pass up.
» cooling system size for 578 - cracked A460 block after all
» A460 block main caps
» Main studs in a460 block ?
» A460 block main bore dia
» Need New Outer Main Bolts for A460 Block
