A460 block main bore dia
New a-block main bore measuring 3.186. About how much metal will alien honing removed?
tconnection- Posts : 866
Re: A460 block main bore dia
3.191 /.192 + or - is the main housing bore diameter. You should be able to align hone and get that .005 or .006".
Charlie
Charlie
c.evans- BBF VENDOR SPONSOR
Auctually im tinkering with bearing clearance.
?, can you use main bore dia minus bearing thickness then take that answer minus main journal dia to get clearance?
If you are going to do that why not just put the bearing in and measure it then Mic the crank and do it right...
the Coug- Posts : 3055
[="tquotehe Coug"]If you are going to do that why not just put the bearing in and measure it then Mic the crank and do it right... [/quote]
x2, I would think that bearing crush in the block might have some effect to your final measurement.
racnrick- Posts : 462
racnrick wrote:[="tquotehe Coug"]If you are going to do that why not just put the bearing in and measure it then Mic the crank and do it right...
x2, I would think that bearing crush in the block might have some effect to your final measurement.[/quote]
Yes Rick it will affect it, but some people try to make it harder than it really is.....
Thanks men. Im getting ready to go to the machine shop, waiting on rings and was just looking into bearing clearances.
» maybe on here alrady but wondering max bore on an a460 block?
» how much is a 1972 429 4bolt cobra jet block worth.. Just the block and main caps.??? std bore
» A460 block main caps
» Big bore FRPP A460 block
» a460 big bore block for sale. brand new
