Big bore FRPP A460 block
+6
AZFairlane
10 posters
Big bore FRPP A460 block Empty Big bore FRPP A460 block
Post  Lem Evans May 3rd 2012, 6:30 pm
It finally got done. They will be available before the end of this month. Prebored to be honed to 4.500".
Big bore FRPP A460 block Empty Re: Big bore FRPP A460 block
Post  bruno May 3rd 2012, 7:13 pm
what is the additional cost gonna be Lem ??
http://WWW.CKRME.COM
Post  richter69 May 3rd 2012, 7:18 pm
how big will it go? I may be starting a new build late this summer.......... Wink
Post  Lem Evans May 3rd 2012, 7:26 pm
bruno wrote:what is the additional cost gonna be Lem ??
Less than $100 I suspect.
Post  Lem Evans May 3rd 2012, 7:30 pm
richter69 wrote:how big will it go? I may be starting a new build late this summer.......... Wink
The blocks are the same....it's just that there will be little or no boring required...depending on needs.
I always wanted to see a 638" engined Grande' Very Happy
Post  bruno May 3rd 2012, 8:31 pm
damn this is gonna be a hot piece
Post  AZFairlane May 3rd 2012, 9:47 pm
Will an A460 block take a 5" crank?
AZFairlane
AZFairlane
Post  Lem Evans May 3rd 2012, 9:51 pm
AZFairlane wrote:Will an A460 block take a 5" crank?
It'd go in there but a taller deck ht. would be needed to make the package work.
Post  richter69 May 3rd 2012, 9:53 pm
at 605 I gotta weigh 3250, 638 its 3400...............I gotta check on the heads, I'm pretty sure the A head is good to go............might be some stuff for sale come late summer.............
Post  res0rli9 May 3rd 2012, 9:56 pm
( at 605 I gotta weigh 3250, 638 its 3400...)
soo just put a little more on your dinner plate Smile by the time its ready you will be to.
Post  Lem Evans May 3rd 2012, 9:57 pm
C460 @ 600 c.i.d. is the deal then.
Post  AZFairlane May 3rd 2012, 11:07 pm
There's a set of E460 heads for sale, they should work respectably with a 638.
AZFairlane
AZFairlane
Post  res0rli9 May 3rd 2012, 11:32 pm
AZFairlane wrote:There's a set of E460 heads for sale, they should work respectably with a 638.
They are already sold...quick
Post  schmitty May 3rd 2012, 11:52 pm
I think the E heads were made to go on the A500 block, and some changes need to be made to get them on the A460 block.
Post  res0rli9 May 4th 2012, 1:01 am
Yep, They have the E460 head bolt pattern. They will NOT bolt up to a 429/460 block without relocation of
the head bolt holes
Post  wvmudder May 4th 2012, 2:57 am
Is this big bore A460 block an option or will all A460 blocks be coming this way now?
Dave S.
wvmudder
wvmudder
Post  powerstrokeace May 4th 2012, 8:13 am
Lem Let us know How much...
Ace
powerstrokeace
powerstrokeace
Post  kjett May 4th 2012, 8:20 am
powerstrokeace wrote:Lem Let us know How much...
Ace
Yeah, some of us (ME!) need to break open the kiddies piggy banks so I can order one Embarassed
kjett
kjett
Post  stanggt May 4th 2012, 8:30 am
Hey Lem, what else needs to be done to these blocks beside finish hone? is the main line ready to go,lifter bores,should they be bushed, ready for cam bearings?
thanks
Chris
stanggt
stanggt
Post  kjett May 4th 2012, 8:34 am
stanggt wrote:Hey Lem, what else needs to be done to these blocks beside finish hone? is the main line ready to go,lifter bores,should they be bushed, ready for cam bearings?
thanks
Chris
If it's like the original a460 block, pretty much everything needs to be checked. At minimum a line hone on the mains and a check on the cam tunnel. Check of the deck as well. It's a new block, it all needs to be looked over to match your specific needs. This deal just saves the cost of the boring as it starts at 4.5, all else is the same.
kjett
kjett
Post  Lem Evans May 4th 2012, 9:51 am
It is the same block only with the bigger bore. The original std. bore block is still available. It's A460BB suffix.
