Looking for a set of rail-type rocker arm assemblies.. '70 429/460 engine
Looking for a set of rail-type rocker arm assemblies.. '70 429/460 engine Empty Looking for a set of rail-type rocker arm assemblies.. '70 429/460 engine
Post  fordloverracing April 29th 2019, 1:10 pm
I need another set of '70 429/460 posi-stop rocker arm assemblies.. includes the arms, fulcrums and tapered posi-stop nuts. Could also use a set of stock pushrods too. Also looking for someone that has quantities of 429/460 engine bolts, etc.. i.e... cylinder head bolts, oil pan & valve cover bolts, timing cover & water pump bolts, crank bolt/washers, cam retainer/bolts/eccentrics, exhaust manifold bolts, fuel & oil pump bolts. I have just about run out of stock engine bolts and need to re-stock. Bolts can be dirty but I don't need any damaged junk. Thanks for any help, Rick.
fordloverracing
fordloverracing
Looking for a set of rail-type rocker arm assemblies.. '70 429/460 engine Empty Re: Looking for a set of rail-type rocker arm assemblies.. '70 429/460 engine
Post  Paul Kane May 8th 2019, 2:22 pm
fordloverracing wrote:I need another set of '70 429/460 posi-stop rocker arm assemblies.. includes the arms, fulcrums and tapered posi-stop nuts. Could also use a set of stock pushrods too. Also looking for someone that has quantities of 429/460 engine bolts, etc.. i.e... cylinder head bolts, oil pan & valve cover bolts, timing cover & water pump bolts, crank bolt/washers, cam retainer/bolts/eccentrics, exhaust manifold bolts, fuel & oil pump bolts. I have just about run out of stock engine bolts and need to re-stock. Bolts can be dirty but I don't need any damaged junk. Thanks for any help, Rick.
Rick I pretty much have every bolt and fastener and valve train component that you are looking for....1968-1971 rockers, ball trunnions, pushrods, etc, lots of head bolts, cam retainers, crank bolts & washers, etc etc etc. Give me a call directly if interested and we'll put together a package deal.
