Valve spring choice
68galaxie
Valve spring choice Empty Valve spring choice
Post  68galaxie May 4th 2019, 11:15 am
I think it may be time to replace the valve springs.
I have Manley 221424 springs installed. They check out at 250 to 265 lbs @ 2.00"
The car is driven perhaps 100 miles a year - street driven with occasional blasts to 6600 rpm.
Springs are 10 years old - but still check out as far as seat pressure goes.
3 choices:
Manley 221424 (leaning to this again)
PSI-1224
PAC-1224
Solid roller cam (276/290 .454/.450 lobe), stainless Ferrea valves.
Cheers
68galaxie
68galaxie
Valve spring choice Empty Re: Valve spring choice
Post  Lem Evans May 4th 2019, 8:20 pm
If those Manley "blue stripe" springs have not broken an inner spring and still check good for pressure I'd give them another year.
Post  kjett May 6th 2019, 8:24 am
Lem Evans wrote:If those Manley "blue stripe" springs have not broken an inner spring and still check good for pressure I'd give them another year.
^^Yep
kjett
kjett
Post  away May 6th 2019, 9:06 am
Dang......apparently I have been changing mine way sooner. But I am bracket racing which I guess is different than what he is doing I guess.
away
away
Post  rmcomprandy May 6th 2019, 2:13 pm
When valve springs "break" it is 99% of the time during the initial run. After that, they simply deteriorate; sometimes quickly but, most of the time it happens slowly.
So, if you have a good spring which has not yet deteriorated past "runable", I would use what has been tested.
Post  Lem Evans May 6th 2019, 2:34 pm
rmcomprandy wrote:When valve springs "break" it is 99% of the time during the initial run.  After that, they simply deteriorate; sometimes quickly but, most of the time it happens slowly.
That's what I've observed with those 'blue stripe' springs.....if an inner spring breaks it'll happen in the first 20 or so passes.
Post  68galaxie May 7th 2019, 1:51 pm
Thank you all !
68galaxie
68galaxie
Post  RCKTBRD63 September 18th 2021, 2:35 am
68galaxie wrote:I think it may be time to replace the valve springs.
3 choices:
PSI-1224
PAC-1224
Cheers
I am also looking for valve springs / here the corresponding thread
https://www.429-460.com/t24043-boosted-460-timing#317659
Could somebody be so kind and post a reply? Thank you so much!
RCKTBRD63
Post  RCKTBRD63 September 25th 2021, 7:06 am
Any comments here? I am sort of stuck without knowledge.
RCKTBRD63
