Fuel filters before my pump ok?
duff429
Fuel filters before my pump ok? Empty Fuel filters before my pump ok?
Post  duff429 June 4th 2019, 10:41 pm
Running my fuel lines, -8an black braided nylon line, 40 micron just after tank than thinking a 10 micron up front before I go to a Edelbrock machanical pump than 8an to carb. 547 street motor. Over thinking it or run it? Thanks
duff429
duff429
Fuel filters before my pump ok? Empty Re: Fuel filters before my pump ok?
Post  stanger68 June 5th 2019, 7:16 am
I've never seen any adverse affect from running a filter in front of my pumps. never tried 2 filters. may be a little overkill.
Post  bosshoss June 5th 2019, 9:09 pm
a 10 micron filter on the suction side of any fuel pump seems like a bad idea to me.
dkp
bosshoss
bosshoss
Post  duff429 June 6th 2019, 5:23 am
Your right I think I was thinking of electric pump. Any suggestions on what to use?
duff429
duff429
Post  rmcomprandy June 6th 2019, 7:19 am
duff429 wrote:Your right I think I was thinking of electric pump. Any suggestions on what to use?
Anything more than a simple screen type filter is to much restriction on the inlet side.
Post  Gregaust June 7th 2019, 5:46 am
A Magnafuel twin stack Prostar 500 pump uses a 70 micron on the inlet , then specify 25 micron before the reg
Gregaust
Post  duff429 June 7th 2019, 4:43 pm
Gregaust wrote:A Magnafuel twin stack Prostar 500 pump uses a 70 micron on the inlet , then specify 25 micron before the reg
Greg I decided to just run a machanical pump. Stock tank Robb mc sending unit, half inch line and pro system 1000cfm. Looks like just get a 100 micron and s screen filter up by carb from what I gather here. Thanks
duff429
duff429
Post  Gregaust June 8th 2019, 1:42 am
I was just using that as a guide as an example. I followed their setup and all works sweet. The same would apply to mech pump IMO.
Gregaust
Post  Curt June 9th 2019, 6:38 pm
I run a mechanical pump with a filter between the tank and the pump. However, I filter the fuel from the drum to the jug, and then the jug to the tank. If you're still getting debris, you're having other issues.
