intakes
intakes Empty intakes
Post  57ford June 11th 2019, 9:57 am
Hi all, street/strip motor , you got a choice between edelbrock rpm or weiand , which one would you use ? what else is out there ? remember lot of street use ! cheers guys .
57ford
intakes Empty Re: intakes
Post  rmcomprandy June 11th 2019, 10:32 am
57ford wrote: Hi all, street/strip motor , you got a choice between  edelbrock  rpm or weiand , which one would you use ?  what else is out there  ?  remember lot of street use  ! cheers guys .
Edelbrock "RPM". The Edelbrock "Air Gap" will make a bit more power at the cost of some off idle, low speed power.
Post  dfree383 June 11th 2019, 6:24 pm
RPM
intakes Empty RPM
Post  57ford June 12th 2019, 4:53 am
Any difference /preference to RPM OR RPM AIR GAP ?
57ford
Post  rmcomprandy June 12th 2019, 10:46 am
57ford wrote:Any difference /preference  to RPM OR RPM AIR GAP  ?
As I said previously, the "Air-Gap" will make a bit more power at the cost of some off idle low, speed power.
The runnners are the same shape but, have a bit larger cross-section.
That is your choice to make.
intakes Empty RPM AIR GAP
Post  57ford June 12th 2019, 10:51 am
Thanks guys, air gap it is then Wink
57ford
