dooe vs d2oe cast intake
are they the same?
jesse- Posts : 447
Re: dooe vs d2oe cast intake
I wouldnt think so cj has larger ports tha police interceptors.
lghting94- Posts : 762
PI intakes.
My '72 PI intake has CJ sized ports and a Ford spread-bore carb pattern. Never seen a intake with D2OE on it.
fordman460- Posts : 100
basicly i was wondering the diff between a dooe intake and a p.i intake
jesse- Posts : 447
intakes.
Ford spread-bore carb pattern would be the only difference.
BOTH have the same port size,but with just a little touch with a die grinder a 4150 will bolt to the pi,look close,the real cj you cant do this, the pi has a 4150 bolt pattern
-RICH
-RICH
BOSS 429- Posts : 2371
sounds like eather one will work fine
but i am getting a p.i
\i was mostly concerned about the runners
as far as the spread bore pattern?
can it be cut out? make it like a dual plane
jesse- Posts : 447
yes, cut it out , i use police,and cj for the cast in/out engines i do for pullers,works great
» Edelbrock Performer vs. cast intake
» Sheet metal vs cast intake
» sheet metal or cast intake ?
» cast intake question
» Can I block off DOOE head exhaust crossover port w/o removing intake manifold?
