cast intake question
nitro521
I am running a local heads up class that requires you to run a single 4 cast intake and a convential head. (currently using p-51's) I will be running a new sv1 prosystems carb and I am looking for any advantage in the intake department I can find. Currently I am running a victor and have read about the modified tfs manifold by the Evans brothers. Is there any options out there that I am not aware of? Thanks
nitro521- Posts : 22
Re: cast intake question
No, but if your intake is not ported, you need to have it done. the Victor intake sucks at the transition from runner to plenum, needs a ton of work.
The TFS intake will or should be a big improvement over the Victor.
It is fully ported. What is the info on the tfs piece. How much work invovled to make work?
It's in the works, and it is a hell of a bunch of work to get an out of the box manifold to what the prototype is. Lem said they had a wood model of it at the PRI show last week, so maybe it's getting closer.
IDT-572 wrote:It's in the works, and it is a hell of a bunch of work to get an out of the box manifold to what the prototype is. Lem said they had a wood model of it at the PRI show last week, so maybe it's getting closer.
any pics of that piece ???
bruno wrote:IDT-572 wrote:It's in the works, and it is a hell of a bunch of work to get an out of the box manifold to what the prototype is. Lem said they had a wood model of it at the PRI show last week, so maybe it's getting closer.
Nick,
I don't know if Lem took any pictures of it. But I think they will have one at the winter tech deal.
No i did not think to take picture....worth a 1,000 words they say...unless they are in the bar & grill .
Im hyjacking briefly...
what were the changes made on the new TFS intake (besides the obvious 4500 flange). Sounds as if they made it better in some way?
IcallhimGeorge- BBF CONTRIBUTOR
Kris, I heard that the "mafia" version will not only have the 4500 pad, but will be ported and have raised runners. But gotta wait to see what the final product will be.
kjett- Posts : 1169
Guys,
Let's go to the new thread where Nick has posted the pictures.
Charlie
Charlie
c.evans- BBF VENDOR SPONSOR
» Cast head question?
» dooe vs d2oe cast intake
» scatt cast steel crankshaft question
» Sheet metal vs cast intake
