mini starter
mini starter
So I had been using a DB Electric starter in the old truck with no issues, but got the new alcohol injected motor together for the new truck. There is very little space to move around on this new ride and will have to remove fender panels and the header just to get to the starter, so don't want to chance having an issue with the stock style starter. What's a good quality high torque starter that people are using that will last a while? Tilton? Meziere? CVR? CSR?
kjett- Posts : 1169
Re: mini starter
kjett wrote:So I had been using a DB Electric starter in the old truck with no issues, but got the new alcohol injected motor together for the new truck. There is very little space to move around on this new ride and will have to remove fender panels and the header just to get to the starter, so don't want to chance having an issue with the stock style starter. What's a good quality high torque starter that people are using that will last a while? Tilton? Meziere? CVR? CSR?
A lot of my customers have recommended to me the CVR starter number 5048M; it has a multi positioning head which fits just about every application and enough power to turn over anything.
Re: mini starter
rmcomprandy wrote:A lot of my customers have recommended to me the CVR starter number 5048M; it has a multi positioning head which fits just about every application and enough power to turn over anything.
Thanks! That's the one I was just looking into.
kjett- Posts : 1169
Re: mini starter
That CVR starter looks just like my Summit Racing brand one. A word of caution, make sure you keep the two long screws that hold the motor to the starter housing tight, one of mine came loose and allowed the motor to twist free from the housing and caused an issue with cranking. I replaced the bolts with a stronger version and also added some nuts to keep everything tight.
wickettoby1- Posts : 352
Re: mini starter
The Mezeir is the cats ass
» Help with ford truck mini starter
» 302/c6 mini starter
» Mini Starter and OIl Pan Question
» Mini Hi Torque starter
» Starter wiring , with solinoid on starter and fender
