C6 band adjustment
C6 band adjustment Empty C6 band adjustment
Post  HorsinAround August 21st 2019, 8:27 pm
Need a little advice. I believe normal adjustment for the band is to tighten to 120 in lbs, then back off 1-1/2 turns and tighten the nut. This is what I used for my Broader VB, but I was looking on TCI's site for my spare trans/ TCI Vb, and they say to tighten to 120 in lbs then back off 4 turns. Does this sound right?
alan
http://www.frontpagefab.com
C6 band adjustment Empty Re: C6 band adjustment
Post  Gregaust August 22nd 2019, 4:36 am
No , definitely incorrect .. Their advice about as good as their parts Twisted Evil
Gregaust
Post  Copperhead August 22nd 2019, 7:32 am
Alan,......
I had a Band Adjustment discussion with my Trans builder a few years ago,....and I told him the very same thing about TCI saying to back it off 4 full turns. In a nut-shell,....he told they're dumb as a rock,....and that spec,...is CRAZY. Said it wouldn't even apply the band backing it off that much.
120 in lbs,.......and back it off one full turn.
Copperhead
Copperhead
Post  aquartlow August 22nd 2019, 5:30 pm
IIRC, Transgo instructions state tighten adjuster to 120 in lbs then loosen until you can just turn the output shaft(I did this with driveshaft/slip yoke installed), it wound up being 1 1/4 turns out, then tighten the locknut. Been this way for a while with no issues.
aquartlow
aquartlow
Post  HorsinAround August 22nd 2019, 6:46 pm
Thanks guys. That is in line with what I though.
