Pro-Tree Transbrake Adjustment on a 2 speed
85montess
D. Sea
Base don this weekends test results, my car is leaving way too early for a .500 Pro Tree. I've adjusted my tranbrake button all the way down to maximum travel, which isn't much. Other options are to get another button with a longer travel, adjust the transbrake release or blink
I'm shallow staging so take out that variable.
On a .500 Pro Tree my lights were
-.031
-.036
then a .039 with the button all the way down and I left a smidge late.
So on the way home I was talking to the Coug about the adjustment and when I get the car up in the air this week I'll measure where the bolt adjustment is now. At what point do I stop adjusting the bolt in to slow down the release with no adverse affects to the transmission?
I need to get hold of Chris and see if he remebers where it's set now. I haven't moved the adjuster since I got the trans from Chris.
Plus I don't recall reading about this before so it will be a good learing thread for myself and others.
Thanks guys
-.031
-.036
Thanks guys
D. Sea- Posts : 2768
JW ultra case adjustment
Damon,
I couldn't find this on JW's site, but it is copied out of the Powerglide Handbook.
85montess- Posts : 51
Re: Pro-Tree Transbrake Adjustment on a 2 speed
Thanks Bill, glad you joined us on the NEW and IMPROVED BBF Forum
Hey , Bill don't be slipping on here incognito .............. I didn't know it was you.
I want to talk to you some more about Kieths car before we go and work on it.
I've got some taller front runners if you want to try um.
IDT-572 wrote:Hey , Bill don't be slipping on here incognito .............. I didn't know it was you.
Blake,
I have to slip on here incognito, since I am one of those other guys , but just give me a call when you are ready and I should be able to take a few minutes. I am trying to finish the rebuild on my Ford tractor (what a pain!!!) and I have a couple of dragsters (one with broken motor plate tabs and the other with the lower frame rails broken completely into) to work on.
Later,
85montess wrote:IDT-572 wrote:Hey , Bill don't be slipping on here incognito .............. I didn't know it was you.
Blake,
Later,
Sounds like you've got Butcher and Meher's dragsters over in your shop! You are a busy man.
TJ
Tommyj466- Posts : 322
Curious
What class runs the .500 tree ??
Or is it a track thing ??
Most Pro trees being .400
Rvesterby- Posts : 130
Rvesterby wrote:What class runs the .500 tree ??
Ron,
Open Comp runs on a .500 Pro Tree as well as a local class called Outlaw Bracket.
We are hoping to get a class started called Pro Comp for cars running 8.50 to 9.99 and it will be on a .400 Pro Tree.
Every 200 rpm launch change moves mine .013, every 4 psi down in front tires move +.01, also lower rear tire psi effects reaction time. I have a Bondio terminator long adj button I works good but if your want to stay in a .010 package on the tree it won't do it. Deadenbear makes a adj button worth about .035 on the full adjustment. My advice try some larger fronts with low psi.
P.S Seen a real long spool of wire too increase the resistance to the T/B I've seen that trick before
BIGDOG466- Posts : 265
I got the button in over the weekend. I'll see how it reacts this next weekend. I only have two spacers in it right now. Front tires are at 35psi and I have a 3900 chip in the box.
Thanks for all the advice and tips
» Need help swapping a Q-Stick shifter from 3 speed to a 2 speed...
» Liberty 3 speed or 4 speed
» pro tree
» Thunderbolt clone
» Post your trees
» pro tree
» Thunderbolt clone
» Post your trees
