Will this small crack in the block where a timing cover bolt/stud goes be a problem?
Will this small crack in the block where a timing cover bolt/stud goes be a problem? Empty Will this small crack in the block where a timing cover bolt/stud goes be a problem?
Post  Landship_Captain August 25th 2019, 11:15 pm
While I was finishing installing my rods and pistons I noticed this small crack.
Hopefully these pictures work right
Images are large:
So, will this be a problem? Should I try to get it welded or repaired in some way? Would it be a bad idea to drill a small hole at the end of the visible crack so it can't progress further as easily?
Landship_Captain
Will this small crack in the block where a timing cover bolt/stud goes be a problem? Empty Re: Will this small crack in the block where a timing cover bolt/stud goes be a problem?
Post  rmcomprandy August 26th 2019, 10:15 am
Put a layer of JB Weld epoxy over it and don't worry about it.
Use a sealant on the bolt and be sure the bolt threads extend past the end of the crack.
