Valve cover stud
+6
Wayne Pearce
butterbean
gmsmkr
460Dave
10 posters
Valve cover stud
I thought I might share this and prevent someone else from the same fate.
A valve cover hold down stud on a P51 (and I think on the A460) can, and will, work its way into the intake runner and on top of the piston.
Mine were red loctited into the wing nut hold down, but one came loose and made lots of noise while driving through the water box. Only bolts for me from now on.
460Dave- Posts : 108
Re: Valve cover stud
Also on the frpp scj heads....
gmsmkr- Posts : 1364
And factory iron CJ's
Not on A460's
did this just happen over the weekend???
butterbean- Posts : 676
yes, Friday night... on the 6th pass of the evening
Damn that sucks, did you get any good passes in before this happened???
I guess one way to assure that doesn't happen to your engine is to use "real" studs" (pardon me for not knowing the proper terminology), such as ARP valve cover studs, 1/4-20 lower end, with 1/4-28 upper end - they physically cannot work their way into the intake port. They may be expensive, but not nearly as expensive as a grenaded motor. Believe me when I say I'm NOT trying to be a sarcastic - just trying to be helpful.
Wayne (SAWDOFF) Pearce
Wayne Pearce- Posts : 658
One could also gall the threads a bit at the center of a piece of allthread, but Wayne's solution is best.
maverick- BBF CONTRIBUTOR
when was using a429 heads i tigged a small "bead" on the stud so it would have a stop on the stud. never broke and they lasted for years.
norm- Posts : 261
I use 1/4 20 allen head bolts put them in with a tee handle allen wrench
I like the ARP valve cover studs because they have the "ball nose" on them, and it makes it a whole lot easier to drop the washer on, and start the nut. Being that the threads are "rolled", the nut starts easy, and spins down the length of the stud with no hang ups.
460Dave wrote:I thought I might share this and prevent someone else from the same fate.
A "set screw" type stud very easily can but, a stud with a thread break in the middle with fine threads on the top will not.
» Any certain valve cover fit the P51 better than others?
» Will this small crack in the block where a timing cover bolt/stud goes be a problem?
» GT 598 1968 mustang
» valve cover gaskets ......
» Motorsport valve cover set SOLD
